I'm trying to render a boat hull. Indigo was working fine for a couple of weeks but then it started to render only a portion of the Sketchup view.
After playing with the render settings for a while, I just opened up a new skp and imported the hull into that. When I tried to render, it worked fine for a couple of renders and then started to render only a portion again. (No settings were changed in the mean time.)
The Sketchup window and the rendered images are below.
Thanks for any suggestions.
murat
Indigo rendering only a part of the view
Re: Indigo rendering only a part of the view
What version of SkIndigo are you using? Make sure you are rendering a perspective view.
New versions do not allow non-perspective view renderings, while older versions will render it but not correctly (as in your case)
