Error: Error while packing scene: failed to load XML doc
Come here for help & support.
4 posts • Page 1 of 1
georglorenz
Post by georglorenz » Wed Feb 08, 2012 8:29 am
Error: Error while packing scene: failed to load XML doc from path 'C:\Users\gxl\AppData\Local\Temp\indigo_temp_dir_1328646153\temp.igs': Error reading end tag. (Line 144, column 23.)
I am trying to pack a scene to send to the RANCH computing render farm. Never did this before. Please help.
Thank you /gxl
I am running:
Indigo RT v3.2.0, Windows 64-bit build.
Licence Verified
Licence Type: Indigo RT
Re: Error: Error while packing scene: failed to load XML doc
Post by OnoSendai » Wed Feb 08, 2012 8:53 am
Please try upgrading to Indigo 3.2.7: http://www.indigorenderer.com/forum/vie ... =1&t=11434
And re-exporting, then re-packing the scene.
georglorenz
Post by georglorenz » Thu Feb 09, 2012 4:05 am
Thank you for the timely reply. Unfortunately I still get the same error:
Error: Error while packing scene: failed to load XML doc from path 'C:\Users\gxl\AppData\Local\Temp\indigo_temp_dir_1328716679\temp.igs': Error reading end tag. (Line 144, column 23.)
I reinstalled indigo 3.2.7 per your advice, but it shows the following in the Help Menu:
Licence Verified
Would a correct install of v3.2.7 show itself in the help menu???
georglorenz
Post by georglorenz » Thu Feb 09, 2012 4:25 am
Well. I guess I just answered my own question. Worked fine after I completely uninstalled and installed again. Thank you / g
