Circulary brushed metal
3 posts • Page 1 of 1
dcm
Post by dcm » Fri Feb 25, 2011 2:08 pm
Someone asked here for this so here is it. Material incl. refl. map too but i prefer to use bump only because of larger variery of reflections. Previews bottom. You will have to adjust bump value probably - all depends on look you are searching for. I advice to use upper value max 0.65. For softer look use 0.25 +.
glossiness value = 18
without refl. map :
with refl. map :
Material : http://www.indigorenderer.com/materials/materials/836
galinette
Re: Circulary brushed metal
Post by galinette » Fri Feb 25, 2011 10:45 pm
I love this!
Should be made procedurally!
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
dcm
Post by dcm » Fri Feb 25, 2011 10:52 pm
Thanks...you are master, try it :D
