M2I 0.612
- Kosmokrator
ok i make some changes to scene to upload it...and tha same prob here...take a look..
http://rapidshare.de/files/27925727/indwhiskey.zip.html
Ok i went for some short tests.. i couldn't resist ..
The problem was you were using very high settings for exposure AND
the reinhard tonemapping....
Try to keep the following workflow.. to have full control..
(1) first set the exposure correct.. that the important object is well
exposed ..
(2) use reinhard tonemapping to reduce too bright areas
I used exposure 1/500 and iso 100 .. that gave a good picture.
IMO reinhard is only necessary if you have geat difference is brightness.
Hope that helped.
cheers
u3dreal
exposed ..
Hope that helped.
cheers
u3dreal
- Kosmokrator
- Kosmokrator
Yeah i know .. i had this in earlier versions... and it really slowsKosmokrator wrote:u3dreal ....a progress bar while exporter exporting the max scene it will be very nice idea...what do u think?
down exporting... so you just have to look at the status text... to
see it is still working...
cheers
u3dreal
- afecelis
Hi U3dreal,
I've been testing your latest script with max 6 and Indigo beta 0.6 and things were working quite OK, but as a beginner, Radiance and others recommended me to use the 0.5 stable version instead as some things are broken in 0.6, but now when I hit the "render" button on your script I get this error message:
I know it's a path thing, but where do you set it? (besides the m2i.ini)
Hmm the latest exporter is supposed to run with 0.6 test1 so i'm unsureafecelis wrote:Hi U3dreal,
if it works with 0.5-.... try 0.6 test1 and it should work...
cheers
u3dreal
Hey guys !
I'm new here. I just found out about this Indigo renderer and i'm quite eager to test it =) I ran into a small problem though. It seems, that the download link to u3dreal exporter for 3ds max is password protected. As far as i understand, then this is the latest and greatest exporter for 3ds max. Am i right? If so, then from where can i get it? Are there any mirrors or..? I checked from the main page, but the scripts there seemed to be older ones than this.
Thanks in advance!
Suvakas
Thanks in advance!
Suvakas
Link
I cant get the exporter is says i am forbiden. I really want to tyr the new indigo with the new exporter in coop. I have a 10 dual xeon renderfarm that i really want to test. But for the life of me i cant find where to get the exporter.
Mark
somersault.net
Mark
somersault.net
