by BbB » Wed Jun 18, 2008 8:29 pm
I'm having the same problem Enrico. I get memory crashes with even relatively simple scenes. I reverted to 1.0.9 for now but I know SmartDen is looking into the size issue.
SmartDen
by SmartDen » Wed Jun 18, 2008 8:45 pm
i know the bug and i already working to fix it. be patient
Check normals, dude!
by Borgleader » Wed Jun 18, 2008 10:06 pm
5OnIt wrote:Borgleader... You're not paying attention to the "\.." after the "\preview" directory. It's bumping you up one level. In other words, it's not looking it the textures directory in previews. It's up one level in the Indigo directory.
If you create your own textures folder there and add the file, it should work. That's how I fixed it.
A more permanent solution may be to edit the path in the IMPmatdb.igs file, but I haven't tried that.
About the message, I didnt notice it because I thought windows was treating it sort of how like Firefox treats too long URLs and crpped it by adding \..\ in the middle.
Well I tired it, and it worked. If you change all 4 paths (for preview_logo.jpg, preview_ss-bar.jpg, preview_squaretile.jpg, ...) but now I'm getting and error about 0 UV settings being set which I think was posted a few pages back.
Exact message:
- WTF_Indigo2.jpg (57.52 KiB) Viewed 5310 times
SmartDen
by SmartDen » Thu Jun 19, 2008 3:23 am
hello guys! i have good news. i think i have solved the problem with big files. but before i'll upload the fixed version i'll need some comparing tests with older versions.
palawat
by palawat » Thu Jun 19, 2008 4:32 pm
That's good news, Smart.
My scene got exported as following;
19,959 KB from the 1.0.9
32,192 KB from the 1.1.5
Cheers,
SmartDen
by SmartDen » Thu Jun 19, 2008 8:45 pm
Updated
fixed big-files-bug(hopefully)
Pinko5
by Pinko5 » Thu Jun 19, 2008 8:47 pm
WWWOOWWW tnx Smart!!!
Luca.
delic
by delic » Thu Jun 19, 2008 9:37 pm
I cannot see the script in script window, have to load it from text editor.
Edit :
oh it's registrered as blendigo 1.1.5 for the script menu ...
So I have to delete the old one for the last one to be loaded from the menu.
scyguo
by scyguo » Thu Jun 19, 2008 10:34 pm
Hi!
SmartDen - I've got some sugestion about selecting material to mix (in blend type). Everything goes nice when we have few material, but with a lot of it selecting material has limited becouse list are displayed in single column.
http://img364.imageshack.us/img364/4650/blendigolm6.jpg
delic
by delic » Thu Jun 19, 2008 10:44 pm
Between blendigo 1.1.5 and blendigo 1.1.5_bigfile, the -meshs.xml file sizes are exactly the same.
blendigo 1.0.7: 16'821 KB
Blendigo 1.1.5 : 35'932 KB
Blendigo 1.1.5_bigfile : 35'932 KB
delic
by delic » Thu Jun 19, 2008 10:51 pm
scyguo wrote:Hi!
My workaround for this pb is to rename the needed materials a_material ... Not very smart.
For complex scenes it can be very annoying !
SmartDen
by SmartDen » Thu Jun 19, 2008 10:59 pm
delic wrote:Between blendigo 1.1.5 and blendigo 1.1.5_bigfile, the -meshs.xml file sizes are exactly the same.
remove 1.1.5_bigfile
Pinko5
by Pinko5 » Thu Jun 19, 2008 11:03 pm
I try immediately the new script but now there is this error...
This morning before install new version of blendigo 1.1.5 this scene works fine...
any ideas Smart...
Tnx
Luca.
- kd-tree error.jpg (58.33 KiB) Viewed 5128 times
SmartDen
by SmartDen » Thu Jun 19, 2008 11:06 pm
yes. it's not error on my script!
palawat
by palawat » Thu Jun 19, 2008 11:07 pm
With your new Blendigo 1.1.5, now the .igs size is 12.698 KB
Thank you very much, SmartDen
Cheers,
