SkIndigo 1.1.15
Post by neo0. » Wed Jan 28, 2009 4:15 pm
Sorry, I mean like if you use a blend mat to create etched glass or.. Well.. Hold on
naopachke
Post by naopachke » Sat Feb 07, 2009 9:45 am
does anyone know what the hell is this? and how to correct it?
I'm using skindigo .15 with indigo .15 - and after a correct instalation this appeares when I click on skindigo..
also: no skindigo icons appear on sketchup toolbar?!
crojack
Post by crojack » Sat Feb 07, 2009 9:59 am
make sure that your internet explorer isn't blocking scripts from running
naopachke
Post by naopachke » Sun Feb 08, 2009 1:03 am
i've tried messing around IE settings and no results.. can you be more specific? i have XP and IE7 (but I use firefox)
crojack
Post by crojack » Sun Feb 08, 2009 6:14 pm
All the windows for Skindigo are basically IE html windows so sometimes if IE is blocking javascript it can block Skindigo from working. But, which specific settingss to looks for, other than not allowing javascript, I'm not sure.
naopachke
Post by naopachke » Tue Feb 10, 2009 3:01 pm
I'm going insane here.. I've done all I can think of to IE settings (enabled running scripts from local machine..) - and when I launch skindigo's settings.html directly into IE, it doesn't show any more errors or blocking java and runs nicely, but when I open sketchup and start indigo settings form there, it just won't work. same with skindigo 1.1.12... btw skindigo's render works normaly, so it's definently a java error.
kellpossible
Post by kellpossible » Tue Feb 10, 2009 5:33 pm
I'm sure whaat would be able to help you the most, seeing as he is the one who made the exporter window... Maybe there is some error with the way you have it configured?
Post by Whaat » Wed Feb 11, 2009 3:38 am
In Internete Explorer, try Tools->Internet Options->Advanced->Reset..
naopachke
Post by naopachke » Wed Feb 11, 2009 10:22 am
got it!
first nothing, but after a system restart, all is ok. I'm still a bit puzzled, but who cares when it works. Thanks whaat; thanks guys for your help. :D
xrok1
Post by xrok1 » Wed Feb 11, 2009 11:40 am
Whaat, please check out this post http://asgvis.com/smf/index.php?action=search2
it seems to be happening again with the latest version of skindigo and vray?
i know its pointless to notify AGVIS but i will anyway, i'm hoping you can fix on your end.
BTW besides the annoyance of the message popping up its still seems to function fine.
Users browsing this forum: Bing [Bot] and 92 guests
