Indigo Renderer 4 public beta
- Polinalkrimizei
I also use an i7 2600k, but it is never shown as usable device in Indigo! I was hoping it's graphics unit could be used too...
Also no luck with my 560ti, even with simple scenes / mat preview.
But you devs are awesome, I am planning to upgrade my pc based on the infos in this thread!
How much is the upgrade? I'd like to use V4 for my CPU-renders, but the resolution is to small...
Run in Linux:
./indigo
This application failed to start because it could not find or load the Qt platform plugin "xcb".
Available platform plugins are: linuxfb, minimal, offscreen, xcb.
Reinstalling the application may fix this problem.
Abortado (`core' generado)
Please !!!!!!!!! UNA SOLUCIÓN YA !!!!!!!!!
./indigo
- pixie
OMG there«s a render log! :OProf4D wrote:If the developers wrote the {using all your OpenCL devices NVIDIA, AMD and Intel GPUs} why doesn't it work for the GPU.
When you run Indigo 4.0.31 the result is a black screen.
GT 460
OpenGL 4.1
Driver 364,72
the K2600 CPU
- pixie
you have to specifically install the opencl drivers for the cpu. As for the 560ti i feel you, I have the same problem.Polinalkrimizei wrote:I also use an i7 2600k, but it is never shown as usable device in Indigo! I was hoping it's graphics unit could be used too...
So... those of you on OS X – The NVIDIA panel in System preferences did not detect a newer driver on its own. You can get one here: http://www.nvidia.com/object/mac-driver-archive.html
This changes nothing for me though. Still crashing on Building OpenCL Kernels.
- Originalplan®
:D:Dpixie wrote:OMG there«s a render log! :O
- Originalplan®
Hey Voytech. Can you specify what OSX you are on? 10.11.4? And what kind of mac?Voytech wrote:So... those of you on OS X – The NVIDIA panel in System preferences did not detect a newer driver on its own. You can get one here: http://www.nvidia.com/object/mac-driver-archive.html
- Originalplan®
Hey Prof4D.Prof4D wrote:If the developers wrote the {using all your OpenCL devices NVIDIA, AMD and Intel GPUs} why doesn't it work for the GPU.
GT 460
OpenGL 4.1
Driver 364,72
the K2600 CPU
Try it with a simpler scene.
- pixie
This is the same error I got, even with simple scenes... there are material kinds that it works, but if I change those to phong, for example, I get this error.Originalplan® wrote:Hey Prof4D.Prof4D wrote:If the developers wrote the {using all your OpenCL devices NVIDIA, AMD and Intel GPUs} why doesn't it work for the GPU.
GT 460
OpenGL 4.1
Driver 364,72
the K2600 CPU
- Originalplan®
Hmmm...pixie wrote:This is the same error I got, even with simple scenes... there are material kinds that it works, but if I change those to phong, for example, I get this error.Originalplan® wrote:Hey Prof4D.Prof4D wrote:If the developers wrote the {using all your OpenCL devices NVIDIA, AMD and Intel GPUs} why doesn't it work for the GPU.
GT 460
OpenGL 4.1
Driver 364,72
the K2600 CPU
Do some tests on OSX, on iMac 27, i7 (3,4) - Nvidia Geforce GTX 680MX (2048 M) - Open CL 1,2 - latest CUDA driver.
Open CL drivers are part of OSX and can't be manually updated (only CUDA).
GPU don't works in Mavericks (render window is divided in two square)
On Capitan, crash during open CL build with bedroom scene BUT I can render Erotica scene !
Did someone can do Erotica test with others OSX / material configurations ?
.32 !!!!
:D
:D
- Originalplan®
Hey Patrice.Patrice wrote:Do some tests on OSX, on iMac 27, i7 (3,4) - Nvidia Geforce GTX 680MX (2048 M) - Open CL 1,2 - latest CUDA driver.
Keep in mind that the bedroom scene from Arthur is a pretty heavy scene....TON of geometry in it.
Thats why you can't render it. Your iMac isn't strong enough for it.
I strongly suggest to use El Capitan simply because it has updated drivers.
Another thing to keep in mind for OSX users who are not on a Mac Pro is that OSX only uses the week GPU
(if you have two built in) so either use a manual GPU switching app or switch to higher performance mode in system preferences. On new iMacs or laptops you can ignore this because El Cap will switch automatically...but not on Mavericks.
Ps: Try Oscar's Optimized scene or simpler scenes for testing.Hope it helps.
Did a test render interior scene, MLT with BiDir in Indigo 4.030 a little noisy than in 3.8.29 (
Ok guys I have a SERIOUS problem here: I downloaded and installed the new version but it crashes when launching.
This is the error message:
Firma problema:
Nome evento problema: APPCRASH
Nome applicazione: indigo.exe
Versione applicazione: 4.0.31.0
Timestamp applicazione: 570b0056
Nome modulo con errori: indigo.exe
Versione modulo con errori: 4.0.31.0
Timestamp modulo con errori: 570b0056
Codice eccezione: c000001d
Offset eccezione: 0000000000b1a50e
Versione SO: 6.1.7601.2.1.0.256.1
ID impostazioni locali: 1040
Informazioni aggiuntive 1: 8e1e
Ulteriori informazioni 2: 8e1eb0a44c0ea80a5930cb15b1557e0b
Ulteriori informazioni 3: c12a
Ulteriori informazioni 4: c12adba41c3af9998daae296fd5544c4
Leggere l'informativa sulla privacy online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0410
Se l'informativa sulla privacy online non è disponibile, leggere quella offline:
C:\Windows\system32\it-IT\erofflps.txt
I downloaded and installed the latest nVidia drivers.
I don't know what to say....
Firma problema:
