Grimm
by Grimm » Tue Jun 24, 2008 8:25 pm
YAY!!!!
Thank you sooo much Ono!! Ah, so, err, when is the Linux version going to out?
I guess the only requests that I can think of is access to normal and ray vector angles or at least the tools to calculate them (cross product et al). Conditionals, etc, basically everything.
Grimm on Tue Jun 24, 2008 8:28 pm, edited 1 time in total.
Grimm
by BbB » Tue Jun 24, 2008 8:26 pm
Don't understand zilch.
But I'm sure it'll be great when we see it in action!
Grimm
by Grimm » Tue Jun 24, 2008 8:42 pm
BbB - It means that we might see some of the export writers being able to support procedural textures from the various 3d packages. In this way many of the textures in Blender, for instance, could be replicated in Indigo. This would be a very big programming challenge to do automatically (sorry SmartDen). Mostly I think that this would be used as external textures that you would load in to use. The cool thing is that it allows you total control over your texture. Instead of UV mapping a texture you could just say that any angle in the object mesh that is greater then 45 degrees has a worn metal look and the rest is red paint, for example. Lots of possibilities.
Grimm on Tue Jun 24, 2008 8:57 pm, edited 1 time in total.
Grimm
Grimm
by Grimm » Tue Jun 24, 2008 8:49 pm
Ono - It would be nice to have many of these calculations in simple commands to make it easier to write the textures. I know that it would make your job so much more difficult, but most people will not know the heavy math required by some of this. For myself, I know just enough to get me into trouble. Anyway, just a thought.
Thanks,
Grimm
by BbB » Tue Jun 24, 2008 9:16 pm
Cheers
alex22
by alex22 » Wed Jun 25, 2008 12:00 am
Cool now you can write your own angle-based dust shader!
by Borgleader » Wed Jun 25, 2008 1:04 am
Were gonna need a shader database now
by StompinTom » Wed Jun 25, 2008 2:22 am
i remember the good old days when there were only 3 types of shaders and only about 2 buttons to hit. life was a lot simpler back then.
<sigh>
SmartDen
by SmartDen » Wed Jun 25, 2008 2:47 am
Check normals, dude!
arneoog
by arneoog » Wed Jun 25, 2008 3:38 am
StompinTom, indeed.. >_>
I always handwrote my xml scenes.. :]
..way to complicated to do now.. and I don't have an exporter for my app..
oh well...
But this shader 'system' really looks pretty cool! ^^''
Go, Nicholas!! 8DD
by Borgleader » Wed Jun 25, 2008 3:52 am
@Ono: Will you be doing more shader tests?
by Zom-B » Wed Jun 25, 2008 3:55 am
OnoSendai wrote:Whaat wrote:Yup, basically you embed a short program in the scene file, that describes the albedo, exponent, blend factor, displacement, etc.. of any material.
The program is executed whenever a ray hits the material, and can therefore use such information as the normal at the hit position, hit position, surface uv coordinates at the hit position etc.. to calculate the final colour or whatever
Hmmm... how about processing speed, running the script for each ray hitting the material could
maybe slow down the whole rendering Process if the shaders getting more complicated.
How about GPU support for this part of Indigo, actually this should be a classic GPU homeground...
Check this place for advice:
http://www.gpgpu.org/
Woodie
by Woodie » Wed Jun 25, 2008 4:12 am
SmartDen wrote:
Interesting.
SmartDen
by SmartDen » Wed Jun 25, 2008 4:16 am
by Kram1032 » Wed Jun 25, 2008 4:52 am
Hum... will this also allow mixing emitters with materials?
(If so: hard-cut or smoothly blended?)
Users browsing this forum: DotBot [Bot] and 5 guests
