Indigo 1.1.2
rgigante
Post by rgigante » Tue Jun 03, 2008 10:52 pm
<merge_vertices_with_same_pos_and_normal>true</merge_vertices_with_same_pos_and_normal>
could make our life easier ;) btw...
Thanks for the new release.
Post by pixie » Wed Jun 04, 2008 1:29 am
like <merge_vertices>? :-P
cpfresh
Post by cpfresh » Wed Jun 04, 2008 2:21 am
Thanks, Ono! :)
Post by OnoSendai » Wed Jun 04, 2008 2:31 am
Updated with link to 64 bit build.
Post by BbB » Wed Jun 04, 2008 2:37 am
Now that's wonderful news!
drBouvierLeduc
Post by drBouvierLeduc » Wed Jun 04, 2008 2:38 am
64 bits, yeah ! Now let's render !
Post by OnoSendai » Wed Jun 04, 2008 2:38 am
I'm looking forward to seeing what you can do with it :)
If you spot any problems with normals, uv coordinates, etc... let me know.
alexmeyer
Post by alexmeyer » Wed Jun 04, 2008 2:58 am
Umm... it just crashed on me when trying to do a displacement test. It got to "Doing subdivision level 0" and crashed ("indigo.exe has encountered a problem, blah blah"). Works fine in 1.1.1 though.
The scene is just a UV sphere, with max num subdiv set to 2, and an FBM displace (I don't think it'll work anyway, because I didn't set up the UVs, but that doesn't explain the crash). Exported out of Blendigo 1.1.1.
Scene file attached if you want it.
default.igs
(141.89 KiB) Downloaded 926 times
Post by OnoSendai » Wed Jun 04, 2008 3:08 am
I think it's crashing because there are no UV's.
Thanks for pointing that out.
alexmeyer
Post by alexmeyer » Wed Jun 04, 2008 3:10 am
Ok, I wondered if that was the problem, but figured you should know about the crashing.
Post by Whaat » Wed Jun 04, 2008 3:22 am
thanks ono! did you fix the issues with fbm procedural textures?
Post by OnoSendai » Wed Jun 04, 2008 3:24 am
no, not yet.
aleksandera
Post by aleksandera » Wed Jun 04, 2008 3:58 am
I tried my sss testscene.
It didn't go black yet.
I hope it will clean up before it does that.
Somehow I have that feeling that it whont
However it looks better than before.
Thx and regards!
Aleksander
Post by Kram1032 » Wed Jun 04, 2008 4:23 am
BbB wrote:There you go.
This is a smoothed, low-poly sphere with a diffuse mat and bump map. Rendered with 1.0.9_3
I'm also attaching the scene.
Does it work without bump? I managed to do this in Blender Internal, too. (With the same way to solve it by adding subD) - though I didn't check where it comes from. I just kinda think, it should also happen without bump...
Post by BbB » Wed Jun 04, 2008 4:44 am
As far as I can remember yes. But I didn't check this time.
