+1Zom-B wrote:Glad I could help, looking forward for a updated Forest scene, together with that awesome frog
double sided thin and uvs
Re: double sided thin and uvs
24 hours isn't enough
http://www.werkraum3d.com
I'll see what I can do!
Quick test with my new favourite feature!
I've introduced a new simplified version of the double-sided thin material for sketchup, called 'simple thin':Pibuz wrote:Using two sided materials as they are now conceived it's nearly impossible to SU users. SketchUp doesn't provide proper UVmapping tools, and working THIS long for a leaf is beyond dispute, at least for me.
My former workflor was setting a front texture (most of the times it meant keeping the UV texture coming from the imported or external-referenced OBJ), applying a phong shader and setting a 30% opacity.
..maybe some sort of special SU integration should be made to use this fantastic material. I really can't wait to use it, but now it requires too much work![]()
I would love to see the main Double Sided Material simplified, creating 3 materials just to use only one is not very workflow friendly.
You also end up with quite a chaos of materials in your scene.
Since front & back material can be only Diffuse or OrenNayar, with the only parameter (besides texture map) to be the sigma, it should be easy to include this settings into the Double Sided Thin material and have a closed compact material!
- zeitmeister
Definately +1!
WOW it's been very kind of you, as always!OnoSendai wrote: I've introduced a new simplified version of the double-sided thin material for sketchup, called 'simple thin':
Thanks a lot!
