Thats what i get when i run ./indigo
Program terminated with signal 11, Segmentation fault.
#0 0x08b69b65 in llvm::cl::parser<llvm::FunctionPass* (*)()>::getOption(unsigned int) const ()
with the new beta it is much more worse:Zom-B wrote:do you have that issue with the latest beta too?!
http://www.indigorenderer.com/forum/vie ... =1&t=12389
denis@ubuntu:~/cg/IndigoRenderer_v3.6.14$ ./indigo
indigo: /home/buildbox/Downloads/llvm-3.2.src/include/llvm/Support/CommandLine.h:646: void llvm::cl::parser<DataType>::addLiteralOption(const char*, const DT&, const char*) [with DT = llvm::ScheduleDAGInstrs* (*)(llvm::MachineSchedContext*), DataType = llvm::ScheduleDAGInstrs* (*)(llvm::MachineSchedContext*)]: Assertion `findOption(Name) == Values.size() && "Option already exists!"' failed.
Abgebrochen (Speicherabzug geschrieben)
denis@ubuntu:~/cg/IndigoRenderer_v3.6.14$ gdb indigo core
GNU gdb (GDB) 7.5-ubuntu
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "i686-linux-gnu".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /home/denis/cg/IndigoRenderer_v3.6.14/indigo...(no debugging symbols found)...done.
[New LWP 1855]
[New LWP 1856]
warning: Can't read pathname for load map: Eingabe-/Ausgabefehler.
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/i386-linux-gnu/libthread_db.so.1".
Core was generated by `./indigo'.
Program terminated with signal 6, Aborted.
#0 0xb77c0424 in __kernel_vsyscall ()
(gdb)
Users browsing this forum: No registered users and 103 guests
