Guide For Exporter Writers
Post by Whaat » Tue Jul 31, 2007 8:56 am
In light of some of the optimizations and improvements that have been made to Indigo lately, can you (Ono) give some updated guidance for recommended exporter defaults for MNCR, Bidir, MLT, etc.? Or should we always assume that the values in the inifile.txt are the recommended defaults??
Thanks.
Wedge
Post by Wedge » Sat Aug 11, 2007 7:04 pm
I know you did not ask me but I usually change defaults to match inifile with that particular version of Indigo. :)
Post by Whaat » Thu Sep 20, 2007 9:34 am
What are good allowable ranges for pre-scale,post-scale,burn,linear scale,shutter speed, ISO, exposure (ev), aperture, turbidity, environment map gain? Are the allowable ranges in "Violet" suitable for most people?
manitwo
Post by manitwo » Thu Sep 20, 2007 10:08 am
i use pre-scale:2,post-scale:1,burn:10 most of the time.
CoolColJ
Post by CoolColJ » Thu Sep 20, 2007 10:58 am
whaat - honestly this stuff changes dramaticly frome scene to scene!
there is no ISO or exposure here anyway :)
Post by Kram1032 » Fri Sep 21, 2007 12:55 am
It is, but it wont affect your render, if you use reinhard...
Post by Whaat » Fri Sep 21, 2007 2:42 am
Whaat wrote:What are good allowable ranges for pre-scale,post-scale....
I am curious to what RANGE of values should be supported by the various exporters. For example, what are the ranges in Maxigo, Blendigo, and Cindigo? Do any of them need adjustment?
Post by Kram1032 » Fri Sep 21, 2007 6:15 am
for the perfect setting, ever!
For average Images, I'm quite happy with blendigo's standard settings^^
ah and ISO, shutter speed, et. aren't found in violet.
basically, burn, pre- and postscale should be enough for close to any pic, you want :)
it's contrast / dynamic range (higher burn will bring a wider dynamic range on your pic, but it will also bring a loss of contrast -> grey look might be the result)
gamma, but less destructive than using photoshop (prescale is sort of a smooth gamma, but the other way round. higher prescale means lower gamma)
and
brightness (postscale will directly affect the brightness of your image. if your pic is under- or overexposured, that might be the value, you want to tweak first...
higher postscale = brighter
lower postscale = darker)
Post by OnoSendai » Tue Oct 23, 2007 3:47 am
Added some words on how to calculate aperture radius from f-number to the initial post.
Optics experts, feel free to correct me :)
I don't want to see any magic numbers and other hacks in any exporters for this stuff! :)
rgigante
Post by rgigante » Tue Oct 23, 2007 5:02 am
Ono:
Are Focal distance and Aperture Radius both "mm"?
Thanks, Riccardo.
Post by OnoSendai » Tue Oct 23, 2007 5:05 am
No, all parameters in Indigo use base SI units, which in the case of distances is metres!
rgigante
Post by rgigante » Tue Oct 23, 2007 5:13 am
Ok... XSIndigo fixed! i forget to divide by 2
Big Fan
Post by Big Fan » Tue Oct 23, 2007 6:11 pm
you only got intelligent hacks before because what you had didnt actually work convincingly -its been a hack in Blendigo for a long time without problems :wink:
...actually, I dont think what you have done is right... but nevermind... :wink: :roll:
Post by OnoSendai » Tue Oct 23, 2007 6:28 pm
And why don't u think it's right?
WytRaven
Post by WytRaven » Tue Oct 23, 2007 6:57 pm
Snip! ***self sensorship***
i.e. was not my most constructive post ever.
Users browsing this forum: No registered users and 57 guests
