Test curtains and carpet
Hi this is the first shot for a test on curtains and carpet.
Bye
Delle
Bye
Delle
- im1233681609.png (1.12 MiB) Viewed 18086 times
I use two different materials (with different transparency)
- Tenda bianca (more transparent)
- Tendone (less transparent)
Here are the two materials:
Bye
Delle
<!-- Material : "Tendone (2)" -->
<material> <!-- IgsMaterialType : "IgsDiffuse" -->
<name>Material_54_Diffuse</name>
<diffuse>
<albedo>
<constant>
<rgb>
<rgb>0.800000 0.800000 0.800000</rgb>
<gamma>2.2</gamma>
</rgb>
</constant>
</albedo>
</diffuse>
</material>
<material> <!-- IgsMaterialType : "IgsDiffuseTransmitter" -->
<name>Material_54_DiffuseTransmitter</name>
<diffuse_transmitter>
<albedo>
<constant>
<rgb>
<gamma>2.2</gamma>
</rgb>
</constant>
</albedo>
</diffuse_transmitter>
</material>
<material>
<name>Material_54</name>
<blend>
<a_name>Material_54_Diffuse</a_name>
<b_name>Material_54_DiffuseTransmitter</b_name>
<blend>
<constant>0.050000</constant>
</blend>
</blend>
</material>
<!-- Material : "Tenda bianca" -->
<name>Material_55_Diffuse</name>
<diffuse>
<albedo>
<constant>
<rgb>
<gamma>2.2</gamma>
</rgb>
</constant>
</albedo>
</diffuse>
</material>
<name>Material_55_DiffuseTransmitter</name>
<albedo>
<constant>
<rgb>
<gamma>2.2</gamma>
</rgb>
</constant>
</albedo>
</material>
<material>
<name>Material_55</name>
<blend>
<a_name>Material_55_Diffuse</a_name>
<b_name>Material_55_DiffuseTransmitter</b_name>
<blend>
<constant>0.300000</constant>
</blend>
</blend>
</material>
Delle
Here are the images requested...Curtains are spot on... would love to see a wire frame sometime.
Bye
Delle
- Current Indigo render
- im1233839918.png (697.17 KiB) Viewed 17797 times
- Opengl color view
- OpenGL - Color view.png (680.3 KiB) Viewed 17796 times
- Opengl outline
- OpenGL - Outline view.png (122.57 KiB) Viewed 17795 times
- Curtains wireframe
- Curtain wireframe.png (85.33 KiB) Viewed 17796 times
- Doug Armand
I'd said that is pretty neat - looks quite realistic.
Only comment I have is about the carpet. It looks flat because it appears to be perfectly flat! - maybe try a little bumpage to resemble a real world wear and tear?
and maybe the same for the sofa?
Apart from that I like it. Thanks for sharing the images of your work files - always illuminating
Doug
Doug Armand
Doug Armand
Users browsing this forum: Yandex [Bot] and 29 guests
