Indigo SDK results different from Standalone
7 posts • Page 1 of 1
Post by StompinTom » Wed Feb 20, 2019 2:52 am
Hello,
I don't have access to the SDK board, so I thought I'd post this here...
I have a funny result when comparing an image rendered through the SDK and an image rendered through Indigo Standalone.
What I did was generate the scene via the SDK, write it to XML, render it through the SDK, and then render the output .IGS scene through Indigo Standalone.
Notice the glass on the monkey: in the SDK rendered version, there are black parts where it seems the rays terminate too quickly, which doesn't happen in the Standalone version.
Since the Standalone render is using the same scene, written to XML via the SDK, I'm at a bit of a loss at how to explain this.
The only thing happening between writing to XML and starting the SDK rendering is `renderer->Start()`...
Any ideas?
Indigo Standalone
Re: Indigo SDK results different from Standalone
Post by OnoSendai » Fri Feb 22, 2019 1:20 am
Odd. Rendering with GPU?
Post by StompinTom » Sat Feb 23, 2019 2:53 am
Nope, CPU only...
Juju
Post by Juju » Sat Feb 23, 2019 2:56 am
are the trace depth settings the same?
Post by StompinTom » Sun Feb 24, 2019 12:31 am
They should be. The .igs is written out by the SDK so the settings should be the exact same...
Post by Zom-B » Thu Feb 28, 2019 6:18 am
the subtle difference in Sky color does hint towards GPU rendering too... best double check it Tom.
Post by StompinTom » Fri Mar 01, 2019 10:48 am
That's probably because the SDK image is tonemapped in Blender. I'm not using the GPU in the SDK, and - since I'm writing the scene to .igs just before rendering - the output should be identical, save only if there is a bug in the XML writing code.. :?
