1: compare the nk lists between a phong and indigoShader nodes in a new scene
2: run the command below:
string $tstPath=`optionVar -q indigoRendererPath`+"/nkdata/";
if(`filetest -r $tstPath`)
string $nkList[]=`getFileList -filespec "*.nk" -fld $tstPath`;
string $list2string;
print "\n";
for($i=0; $i < 10; $i++)
print ("File: "+$nkList[$i]+" >> name: ");
string $nkFile = `basenameEx $nkList[$i]`;
print ($nkFile+"\n");
$str = $list2string!="" ? ":" : "";
$list2string+=$str+$nkFile;
else warning "Indigo nkData folder not found !";and if the extension is appearing in the list please post the result of the following:
basenameEx "c:/bibop/techno.dummyExtension"Thanks
If the error persists on that side I can still fix it at export time.
