SkIndigo 3.4.4b
Re: SkIndigo 3.4.4b
Thanks Chris!
Re: SkIndigo 3.4.4b
Wow, thanks Chris and stinkie! I feel all warm and fuzzy inside!
Re: SkIndigo 3.4.4b
Anyone else having trouble with the latest SkIndigo for Mac? I cannot a) get the material presets window to open and b) switch between UI's (so, alas, no sliders for me).
Re: SkIndigo 3.4.4b
I'm still having some troubles when specifying a new path for invalid referenced textures.. I reported this some time ago but never got the same issue (maybe I never got the chance to..): the main problem is that if I point to a texture which has the same name as the previous, not found, even if in a different and defined path the square remains red, and no texture is attached. I have to actually RENAME the texture to have it correctly picked...
..Don't know if I explained my problem clearly enough though
Re: SkIndigo 3.4.4b
What OS? What version of Safari? What version of SU? I don't think I changed anything in SkIndigo that would affect the Mac this way. Do you have an old version to try that you could compare with that you know used to work?Stinkie wrote:Anyone else having trouble with the latest SkIndigo for Mac? I cannot a) get the material presets window to open and b) switch between UI's (so, alas, no sliders for me).
Re: SkIndigo 3.4.4b
I understand what you are saying. This needs to be fixed but I won't be able to do it for the next stable release (3.4). I'll try to get it done soon after. Thanks for the reminderPibuz wrote:I'm still having some troubles when specifying a new path for invalid referenced textures.. I reported this some time ago but never got the same issue (maybe I never got the chance to..): the main problem is that if I point to a texture which has the same name as the previous, not found, even if in a different and defined path the square remains red, and no texture is attached. I have to actually RENAME the texture to have it correctly picked...
Re: SkIndigo 3.4.4b
Hi Dale. I'm using OS 10.5, Safari 3.0.4 and SU 8. I will check tomorrow whether installing an older version of Indigo and SkIndigo solves my problem.
Re: SkIndigo 3.4.4b
Updated OS and browser, and all is peachy now.
