We have seen that bug before, and it should be fixed in the next version (but if you can maybe send a simplified scene where that problem is present to support@indigorenderer.com, that would be very helpful).Ashwini Parashar wrote:Indigo render does not even start rendering. It displayed attached message.
This is one that I thought was fixed in one of the earlier versions. Can you maybe send a simplified scene with that problem to the address mentioned above. It will help fixing the problem.Ashwini Parashar wrote:This is one more problem which we are facing while trying to render from revit, with its default materials. Some of the components come out of the wall face ( as highlighted in image)...
Please give your suggestions...
Thank you for all you feedback, even though it shows that we still need to put a lot more work into Indigo for Revit, but after all, it is still a beta. We will try to fix all the bugs you came across as soon as possible and I will send you a mail with an updated version soon.
Kind regards,
Yves
