Some questions for newest exporter
5 posts • Page 1 of 1
Kosmokrator
Post by Kosmokrator » Tue Nov 20, 2007 8:39 am
hi suv...i have some questions in new releas of exporter....
first of all...how i can use ies lifgts? via standard lights of max or (?) i search in emmiter material type and i non found any new add..
second question is......how i van setup my scene with new camera model?
i play with parameters like iso s/speed ect and nothing happents...is there an enable somewhere?
third....what is the EV value? i nevere seen it on other apps....and this does nothings too... :?
the previwes material is awsome and works very good!
thnx suv or every other for reply!
sth
Re: Some questions for newest exporter
Post by sth » Tue Nov 20, 2007 11:32 am
Kosmokrator wrote:hi suv...i have some questions in new releas of exporter....
For ies lights:
Use max photometric/target or free point light
Distribution: Web and choose your favourite ies ;) Kelvin radiobox - temperature, filter color - rgb light
For camera:
Make sure you've got checked "use custom camera response function" on advanced settings tab, and browse for yourindigofolder\data\camera_response_functions\dscs315.txt or any else. I also set tonemapping to none and I played with the settings.
Unfortunatelly for me maxigo forgets camera response path when i reopen file
EV:
EV, ISO, shutter, F-stop are typical settings in photography. Shortest saying... EV positive values makes your image brighter and negative values darker. I didn't check yet if/how it is working in Indigo ;-) :wink:
I hope it help a bit :)
[edit]
probably playing those parameters changed nothing because you had enabled rainhard...
Post by suvakas » Tue Nov 20, 2007 4:38 pm
sth wrote: For camera:
You don't have to do that if you want to use the standard dscs315.txt function file. dscs315.txt is always used by default. Use the "use custom camera response function" when you want to use something other than dscs315 (someone posted several different function files to the forum). So the camera tonemapping is always On except when you use Reinhard.
sth wrote: Unfortunatelly for me maxigo forgets camera response path when i reopen file
That's a bug. Thanks!
sth wrote: [edit]
Yes, when using reinhard then camera tonemapping wont work. Cant have 2 different tonemapping models at once.
filippo
Post by filippo » Tue Nov 20, 2007 9:06 pm
Hi, some week ago I do some manual and tutorial for maxigo and indigorender, now I want up-date the manual whit the new option ...
Can you tell me all the infromation about the new option?
filippo
sorry for my poor language
Kosmokrator
Post by Kosmokrator » Wed Nov 21, 2007 9:59 am
thnx for answers now all its clear!thnx
