ITS TIME FOR NEW....
Kosmokrator
Post by Kosmokrator » Mon May 14, 2007 12:28 am
i think its time for new maxingo exporter!what u think suv?release test3 is out! :wink:
Post by suvakas » Mon May 14, 2007 1:44 am
yeah... i'm working on it.
What do you guys think, how i should implement the new diffuse transmitter material? Should i add it as a new material type or should i put it under some of the existing materials?
I'm thinking, that there are quite many materials already. Would it be logical if i add it to somewhere under the existing SSS material ? Cause the effect is quite similar to sss effect.
Or do you have any better ideas?
Let me know what do you think!
Post by Kram1032 » Mon May 14, 2007 1:54 am
I can't speak for this, really, but I guess, three possibilities:
1) is, how I'd do it: New Mat
2) is the other way, you mentionet: SSS undercategory
3) as it's called "diffuse" transmitter -> undercategory in Diffuse mat...
Post by suvakas » Mon May 14, 2007 2:03 am
SSS material in max is basically a medium/specular material.
Well..i thought about adding it under diffuse mat too, but i'm not sure if this is the right spot.
I want to place it so that it seems logical and user friendly. I think the effect looks like sss (does it?) so puting it as an option under Specular/SSS seems like a good spot. But i'm really not sure.
There are 7 Maxigo materials already. I think, that there is no need for another one. Might get a bit too "crowded" (if you know what i mean).
So..would be good to hear some users opinions on this....
Post by OnoSendai » Mon May 14, 2007 2:21 am
I would be inclined to keep them separate, for example, you can texture a diffuse transmitter mat, but you can't texture a specular or glossy_transparent mat (sss mats)
Post by fused » Mon May 14, 2007 2:34 am
i would implement it as a seperate material type. that what i did, btw.
Kosmokrator
Post by Kosmokrator » Mon May 14, 2007 3:02 am
for me ...use a separate material!btw....thnx suv!
Post by suvakas » Mon May 14, 2007 3:26 am
Ok. I'll add it as a separate Mat then.
After that there will be 8 different materials:
Diffuse
Phong
SSS
Emitter
Blend
Diffuse transmitter
Null
ImortMat
Quite a lot :)
Post by fused » Mon May 14, 2007 3:28 am
uhm...
whats an ImortMat?
did i miss something?
Post by suvakas » Mon May 14, 2007 3:31 am
It's for importing *igm files.
Post by Kram1032 » Mon May 14, 2007 3:31 am
ImPort, right?
Importmat from igm
Post by fused » Mon May 14, 2007 3:33 am
ah.. ok ^^
vansan
Post by vansan » Mon May 14, 2007 7:43 am
I'd do a single Indigo_Material if I'd write my own 3dsmax-exporter,
then made a dropdown menu(in example, maybe a radiobutton...) and added there new materials as they are developed. There I'd add a preset-mode for quick selecting often-used materials.
I can make a scripted interface for it if Suvakas will not be against.
Suvakas's material system is good, maybe just too complex for quick use... And simplification of the process is my goal.
Post by Zom-B » Mon May 14, 2007 8:00 am
OnoSendai wrote:you can texture a diffuse transmitter mat, but you can't texture a specular or glossy_transparent mat (sss mats)
We all hope this doesn't stay this way :wink:
Post by suvakas » Mon May 14, 2007 8:56 am
vansan wrote:I'd do a single Indigo_Material if I'd write my own 3dsmax-exporter,
I tried to do it at the very beginning of my little project, but i failed. My problem was, that i couldn't find a method of how to change material interface according to what is selected in drop-down menu. I just don't know the maxscript so well and the help file can sometimes be quite confusing.
I still think, that this would be the best way to organize the materials. I don't like the growing number of separate materials at all.
