Blendigo 1.0.5 Beta
pxl666
Post by pxl666 » Sat Feb 23, 2008 1:29 am
SmartDen wrote:
pxl666 wrote:smartden - could u consider adding an option to indigoresumer "start as a master" for easy resuming network rendering?
what resumer do you mean?
"myresumer" isnt that ur project? sorry if i'am wrong.
and - render region works fine, but suzanne with subsurf (render) on 5 crashes on athlon x2 2.2ghz/2gbRAM... and if i use IES profile - export crashes ...
cheers
pxl666
Post by pxl666 » Sat Feb 23, 2008 1:43 am
Macrob wrote:Works fine here with ies and curves :D
Thanks SmartDen
are u sure it works with IES profile?
SmartDen
Post by SmartDen » Sat Feb 23, 2008 2:19 am
i noticed right now, that the subsurf render level will be not applied. i'll fix it asap.
pxl666
Post by pxl666 » Sat Feb 23, 2008 2:30 am
i use a single face with normal toward object - it crashes when i assign ies profile - what i do wrong?
Macrob
Post by Macrob » Sat Feb 23, 2008 2:57 am
at least it looks that way :)
SmartDen
Post by SmartDen » Sat Feb 23, 2008 3:08 am
pxl666 wrote:i use a single face with normal toward object - it crashes when i assign ies profile - what i do wrong?
what kind of error message do you get? paste it here or make a screen shot and attach it. it would be very helpful
SmartDen
Post by SmartDen » Sat Feb 23, 2008 3:18 am
Update with fixed render levels
Macrob
Post by Macrob » Sat Feb 23, 2008 3:46 am
Hi SmartDen. the last update gives this:
processing Camera...
  Film Width 0.035000
  FOV: 39.966213
  lens-sensor-distance: 0.048125 m
  aperture-radius: 0.003008 m
build_lists
Getting Mesh from Object Circle
  File "<string>", line 2963, in buttonEvt
  File "<string>", line 2311, in exportStill
  File "<string>", line 2289, in export
  File "<string>", line 2042, in exportIndigoScene
  File "<string>", line 1779, in build_lists
  File "<string>", line 1718, in getMeshFromObject
AttributeError: 'module' object has no attribute 'bpy'
the one before didn´t
pxl666
Post by pxl666 » Sat Feb 23, 2008 4:19 am
hmmm now ito works fine
tested:
subsurf - works fine
render region - works fine (does it really speed up render? indigo should stretch cutout region to fill its window - useful for checking details...)
IES profiles - works fine
that was a dirty&quick check - thanks smartden for ur patience!!!
SmartDen
Post by SmartDen » Sat Feb 23, 2008 4:21 am
thank you for testing and quick response
GNUdo
Post by GNUdo » Tue Feb 26, 2008 10:35 am
I have a problem with the last Blendigo (v1.0.5b) under Linux, but IIRC it happens under Windows, too.
Whenever I export a scene with autorun on and then save the scene in Blender, the file grows even if nothing in the scene has changed.
Reopening and saving the file in Blender resets its size.
Does this happen to anyone else?
SmartDen
Post by SmartDen » Fri Feb 29, 2008 6:04 am
bug noticed and will be eliminated soon :)
SmartDen
Post by SmartDen » Sat Mar 01, 2008 1:51 am
Blendigo Updated
Pinko5
Post by Pinko5 » Sat Mar 01, 2008 1:55 am
Tnx Smart!!!
Luca. ;)
GNUdo
Post by GNUdo » Sat Mar 01, 2008 3:42 am
Thank you very much, now it works perfectly.
Keep up your good work!
