REALLY slow rendering
psor
Post by psor » Wed Feb 20, 2008 1:54 am
@pxl666
You've to change two settings ...
me wrote: LM Probability: 0.1 -> 0.4 Who is putting this to 0.1? SmartDen/Wedge? :P
Supersampling: 1 -> 3 Do you know what it does? To make it short, it's an
image scaling factor that helps a lot with noise/fireflies and aliasing artifacts
at high contrast areas. So for final images put it at least to 2, 3 is better.
btw. 9h for an interior with an unbiased renderer, even with three
machines is nothing! And now, have fun! :D ;)
take care
psor
"The sleeper must awaken"
pxl666
Post by pxl666 » Wed Feb 20, 2008 2:34 am
thx psor - so, how long are u cooking ur interiors usually? 20hrs? more?40hrs???
what can u recommend regarding other settings? are they correct 4 this type of scene? what if i change EP's in windows into a glass and will put a textured plane with background? should i change any settings to get things faster or cleaner?
ps i've put supersampling on 1 to minimize my frames - router gets cooked when both slaves are sending frames in same time...but i will give it a try to increase this value
Post by BbB » Wed Feb 20, 2008 3:42 am
20 to 30 hours on a quad core is not unusual for interiors. And that doesn't mean they'll clear up completely. Sunlit interiors are among the toughest scenes for Indigo.
Labello
Post by Labello » Wed Feb 20, 2008 4:20 am
now that we are some kinda far away from the topic i want to ask something else.
i set up the material of the floor with a basic planket-texture. but i always store the textures in my indigo directory because blenigo doesnt write the path of the textures correctly... and even if i store them in the indigo dir i have to delete "../../" in front of every texture-name.
so what is the easiest setup for textures?
SmartDen
Post by SmartDen » Wed Feb 20, 2008 4:25 am
OS? Indigo and Blendigo version?
Labello
Post by Labello » Wed Feb 20, 2008 4:28 am
Linux, last stable version of indigo. Indigo 0.6test6 (beta1) export script
Edit: now im going to upgrade both. indigo and blendigo. so just wait a moment^^
SmartDen
Post by SmartDen » Wed Feb 20, 2008 4:33 am
i suggest you get indigo 1.0.6 and blendigo 1.0.5 beta
Labello
Post by Labello » Wed Feb 20, 2008 4:50 am
got it. but i dont like wine. the new indigo-version works way slower than before. i used the linux-binarie and now i have to emulate it with wine
moreover the paths are still not set correctly
pxl666
Post by pxl666 » Wed Feb 20, 2008 4:54 am
Labello wrote:now that we are some kinda far away from the topic i want to ask something else.
hey - that was issue i was struggling sometime ago but i noticed smartden and afaik he updated blendigo and now it works fine
CHECK "RELATIVE PATHS" SETTINGS WHEN LOADING TEXTURES IN BLENDER
AS BLENDER TENDS TO PUT IT: //textures/texturefile.jpg AND BLENDIGO TRIES TO USE THIS PATH
this should help
