DEV-thread - Blendigo v0.7 - material-editor-exporter
zuegs
Post by zuegs » Mon Feb 19, 2007 7:17 am
@tungee, @Kram1032:
Thx for hint, "MatSssRgb crash" fixed. Please download new version from first post.
Thanks guys :D
Post by Kram1032 » Mon Feb 19, 2007 7:20 am
Thank you very much!
neepneep
Post by neepneep » Mon Feb 19, 2007 7:41 am
Is it possible to allow gain values that are less than 1 ? ie. I want to set absorption to 0.00001 but the least I can get to is 0.001 .
zuegs
Post by zuegs » Mon Feb 19, 2007 7:44 am
@neepneep:
i can extend the gain range... whats about gain=0.001 and R=G=B=0.001 ? Not nice but should work :wink:
[EDIT]: ok sorry i see the problem.... XML values are clamped on 3 digits after period... will update soon... stay tuned :wink:
Post by StompinTom » Mon Feb 19, 2007 7:58 am
this thing is fucking piss! makes it sooo much easier when you actually see what youre tweaking. pretty much as close to integration into Blender as possible right now.
thanks alot!
kepler
Post by kepler » Mon Feb 19, 2007 7:58 am
@ zuegs: I have two problems here.
1. I can't use the old Blender2Indigo07 exporter anymore (I have a python error)
2. If I call a mesh ".sphere" the script doesn't export it as a sphere primitive (like happened with the "old" exporter)
zuegs
Post by zuegs » Mon Feb 19, 2007 8:15 am
@kepler:
1. sorry but this two exporters are independent... expect perhaps of the .conf wrapper.
2. yes it's right, but this script is not the successor of Blender2Indigo07... but perhaps will have time soon to implement the primitives too.
zuegs
Post by zuegs » Mon Feb 19, 2007 8:30 am
@neepneep:
i updated download on first post, this version should now accept RGB absorption gain values below 0.001 :roll:
kepler
Post by kepler » Mon Feb 19, 2007 8:50 am
zuegs wrote:@kepler:
What do you mean? They should work both?
neepneep
Post by neepneep » Mon Feb 19, 2007 8:57 am
:D
I have another one for you - when exporting with an environmap, it will write the wrong path for the EXR file. It seems to go to the "indigo folder path\HDR" ...
melon
Post by melon » Mon Feb 19, 2007 8:59 am
I'm a bit of an Indigo novice, so excuse me if my comment here is off-base...
However, I've noticed that, under "Tonemap," there's no ability to select "Linear" as a tonemapping type. There's just "Reinhard." So I guess if that's a bug, then that should be fixed too.
That aside, this exporter is really very useful, even as an early beta!
As an aside, for those who don't know, Blender 2.43 final has been released. I don't know if Blender.org has been updated yet, but you can download it from here:
http://download.blender.org/release/Blender2.43/
EDIT: Looks as if Blender.org has been updated, after all.
http://www.blender.org/
zuegs
Post by zuegs » Mon Feb 19, 2007 9:31 am
@kepler:
yes they should work both. I can't see any reason why they shouldn't. Could you describe more precisely (error msg, console output) what's going wrong?
@neepneep:
one more :wink: , thx neepneep, you have a good eye :wink: , i uploaded fixed version in first post... should work now (that was an older routine from an older exporter, i haven't realy rechecked it since)
#melon:
yes, "none" stands for "Linear" mapping... i can rename it. Will also have to add a "output igi" button which give the possibility to do tonemapping as a post-process with indigos "IndigoToneMapper.exe".
[EDIT]: ok, i have to go to bed now 8) ... will be back in about 8 hours :roll:
afecelis
Post by afecelis » Mon Feb 19, 2007 11:18 am
@zuegs: all I'm getting after the warmup is a totally washed out white image :? Do you know anything about this? (the png created is only 1k but the igi file is more taht 3 mb).
drBouvierLeduc
Post by drBouvierLeduc » Mon Feb 19, 2007 12:38 pm
Damn, it works perfect. The material preview option is a fantastic idea.
Just like to point out something with indigowrapper.conf under windows xp in case someone have the same issue :
you have to write the path this way :
c:\progra~1\indigo (and not c:\program files\indigo)
F.ip2
Post by F.ip2 » Mon Feb 19, 2007 2:44 pm
mh ok maybe I am missing something but where is the material preview of indigo in blender? I do not see it when I start the export script!
Artist : Designer : Educator
of Ferris State University
