EDIT: Image added.
Blendigo 2.3.x test releases
Re: Blendigo 2.3.x test releases
Camera matching between Blender and Indigo is broken, especially when using Camera Shift. Will provide image to demonstrate a bit later, but it's busted
EDIT: Image added.
EDIT: Image added.
error
SceneLoaderExcep: ObjectExcep: No such uv set 'uv' (In element 'model', around line 162, column 5)
Indigo version: Indigo Renderer v2.4.3, Windows 32-bit Release build.
I get this in Blendigo v2.2 as well
edit - I just deleted all UV references and now it works
Not sure if this has been addressed... I'm using 2.3.3, but external materials don't really work. I can only get one to work at a time, then it throws me the 'Material is not defined' error in Indigo. Took a look through the IGS file, but I can't open the IGMESH files, it's all gibberish. I wanted to check out what materials are being applied to the mesh, because in the IGS file it just gives an <include> where I kind of expected it to be something like,
EDIT: I expected it to be like that because that's how it is defined within Blender: the material name in Blender is arbitrary, it's just linked to the IGM or PIGM data through the exporter.
<material>
<name>blah blah blah</name>
<include>..... material gets included here </include>
</material>
Aww, no official updates in a month
Blendigo 2.4.3 (matching latest Indigo version number) will be released this weekend.
Yay, complaining works!
Seriously though, today seems to be just packed with fantastic news!
You're awesome. Geez, this weekend is great and it hasn't even started yet!dougal2 wrote:Blendigo 2.4.3 (matching latest Indigo version number) will be released this weekend.
Hi Guys,
I didn't quite manage to finish everything I wanted to this weekend, I'll try and get the release out in the next couple of days.
