Returning to Blender from Indigo operation problems.
7 posts • Page 1 of 1
cparks
Post by cparks » Mon May 19, 2008 8:09 am
This may seem out of place, but I am posting this question in two topics. Here and at the Indigo site.
I am using the Blendigo script for the Indigo Renderer on windows xp with Blender 2.45.
Often times when I abort the Indigo render either by using Alt-X in Indigo's independent window or just clicking it closed, I get some hotkey problems.
Usually hitting the S key while having an object selected will enter scale mode - after exiting Indigo and returning to blender - isntead it is asking me if I want to clear the scale values. The same happens for using R to rotate. The middle mouse button stops working for zoom/pan/orbit as well. Ctrl-S and Ctrl-W do not work.
I checked all the different operating modes in blender, tried repeating the process ( which does not consistently happen ) and every other thing I know.
Is there an operating mode that I am in and a hotkey that can get me back to normal ops?
The only way I have found to fix this is to quit blender and restart it.
Post by Kram1032 » Mon May 19, 2008 8:18 am
:shock: Never had that problem... :? A really strange one.
zsouthboy
Post by zsouthboy » Mon May 19, 2008 10:11 am
Sounds like you have a keyboard that is sticking when you hit the alt key.
It's not some wierd interaction within the programs, if that's what you're asking.
cparks
Post by cparks » Mon May 19, 2008 12:28 pm
zsouthboy
If I had a stuck alt key, nothing would work right. Thanks for the thought.
Levon
Post by Levon » Tue May 20, 2008 1:19 am
i get blender freezing some times after Indigo exits.. i need to press Ctrl + Alt + delete, and then close it, and it seems to fix everything.
Xelptic
Post by Xelptic » Tue Aug 05, 2008 10:22 am
heh, i had a same problem(with Blender 2.46)
And I found simple solution: just click on the Blender Console (this tiny second window which appears when you start Blender) and click again in Blender .
Actually Alt+Tab works too :)
Post by StompinTom » Tue Aug 05, 2008 1:14 pm
same problem here. just hit Alt a few times. clears it right up.
