Increasing Brightness / More Light.
6 posts • Page 1 of 1
JDA
Post by JDA » Sat Mar 29, 2008 6:51 am
Hi :)
1
Room with a mesh emitter, RGB White.
Black Body, Gain 1.0, tempature 6500
2
Brightness increaded in Paint Shop Pro X
Question.
How do I get it to be bright in image1 like in image 2
without using more mesh emitters and or Paint Shop Pro's adjust brightness?
jurasek
Post by jurasek » Sat Mar 29, 2008 7:44 am
"Indigo Manual.pdf" ?;)
Page 24 -> Tonemapping, and Violet is your best friend.
greetz,
jur
Post by pixie » Sat Mar 29, 2008 3:04 pm
Well Violet is more or less a Paintshop Pro Lite, with only a very specific subset of features related to image calibration.
Post by OnoSendai » Sat Mar 29, 2008 3:49 pm
It's pretty much a tonemapping problem, JDA.
If using Reinhard, you want more burn.
So lower the burn threshold value from 10. (the default)
JDA
Post by JDA » Sun Mar 30, 2008 2:08 am
Hi
Well here it is after about 5 hours.
I turned the Burned down and it helped.
I'm looking for more light to be evenly
(dispersed /distributed / scattered/ spread) through out the room.
How can that be done without using another application like Violet?
Post by Kram1032 » Sun Mar 30, 2008 10:52 am
...Using the settings, already in Indigo, instead of setting the afterwards in Violet. (And it'll look the same, so Violet actually is an advantage ;))
