Some help installing Indigo 64 bit Linux
pei_tech
Post by pei_tech » Wed Feb 11, 2009 6:54 am
Hello,
Could I get some help/info on installing Indigo on Linux. We have a dual opteron server that I would like to have run our renderings...currently smp 64 bit Debian Etch.
I have downloaded the latest stable 64 bit tar, but I don't see any make files, etc. What is the procedure for installing/running on linux? Does it still require wine?
Any help would be wonderfully appreciated.
eman7613
Post by eman7613 » Wed Feb 11, 2009 7:43 am
make files are only for compiling :P indigo is binary releases only!
sudo apt-get install libwxgtk2.8-0
run that command to make sure you have wxGTK, then just run the binary (you may need to change permissions on the file)
Yes i know, my spelling sucks
pei_tech
Post by pei_tech » Wed Feb 11, 2009 7:48 am
Thanks,
Kind of figured that was the case....Debian Etch only has wxGTK2.6 available as a package...will try to get it from source. Thank you for the reply.
eman7613
Post by eman7613 » Wed Feb 11, 2009 7:54 am
you could just download the deb package from testing, (its in my repo since in using lenny)
pei_tech
Post by pei_tech » Wed Feb 11, 2009 8:45 am
Yes, that is true...was hoping for a quicker fix than to do a dist-upgrade, but I bit the bullet and started the process....thanks again.
eman7613
Post by eman7613 » Thu Feb 12, 2009 3:12 am
O.o, you could have just downloaded that one deb file and any it depended on, but okay - whatever works :o
pei_tech
Post by pei_tech » Thu Feb 12, 2009 3:25 am
You are correct, but what was coming back as dependencies, etc, was so extensive, I decided to just do a dist-upgrade.
eman7613
Post by eman7613 » Thu Feb 12, 2009 5:19 am
ahh, okay. I didn't know how long the dependence tree was :?
Post by PureSpider » Thu Feb 12, 2009 6:34 am
Thats why I upgraded to lenny some time ago :D
Check the dependencies for just the cpp version needed by wx widgets, then you get an idea of the total number of packages ;)
beyer
Re:
Post by beyer » Sun Jun 14, 2009 12:02 am
Linux newbie here.
When I try to run indigo on a Linux machine I get the message:
error while loading shared libraries: libwx_gtk2u_richtext-2.8.so.0: cannot open shared object file: No such file or directory
I understand I need to do something like: sudo apt-get install libwxgtk2.8-0 to get indigo runing. The problem is I don't have a root account on the Linux machine I'd like to run indigo on, and so I can't install libwxgtk2.8-0 directly. Is their some other way I can get indigo running without using apt-get?
Re: Some help installing Indigo 64 bit Linux
Post by PureSpider » Sun Jun 14, 2009 12:34 am
No :(
beyer
Post by beyer » Sun Jun 14, 2009 12:38 am
Thanks for the reply :(
beyer
Post by beyer » Sun Jun 14, 2009 9:44 pm
I've been looking at this a bit more, and it seems some librarys can be installed without root. For example: http://winter.eecs.umich.edu/soarwiki/D ... ermissions
The important point seems to be modifying the LD_LIBRARY_PATH and LD_RUN_PATH variables. Can someone who knows about this stuff have a quick look? Cheers.
Post by PureSpider » Sun Jun 14, 2009 10:38 pm
Wow cool. Didn't know this :shock:
beyer
Post by beyer » Sun Jun 14, 2009 11:27 pm
So do you think it will be possible to install libwxgtk2.8-0 without root and get indigo running?
