SomeQuestionsFromNewUSER
vux
Post by vux » Thu Sep 06, 2007 4:51 am
so i need simple render image atwice and composite it?
Post by Kram1032 » Thu Sep 06, 2007 4:57 am
no....
two ways (both possible to use at the same time)
either, you set more than one renderthread
or you resume the render, after stopping it.
In both cases, you get new seed values ;)
if you resume a render with more than one thread (the combined way), you get both effects, at once :)
I *guess*, if the pic doesn't seem to develop anymore, you need to resume (== use new seed values) - as long as that doesn't happen, you should go on rendering....
I wonder, if there is a "change appearance check" formula, that gives the change of the image over time. if the result is lower than a given value, new threads get started...
vux
Post by vux » Thu Sep 06, 2007 5:03 am
ok we heve two images with same quality and with other noise
wgat about blending mode between them? :wink:
Post by Kram1032 » Thu Sep 06, 2007 5:55 am
one of the violets had the possibility to blend igis... ;)
vux
Post by vux » Thu Sep 06, 2007 5:58 am
i dont understand - violet hat :)
Post by Kram1032 » Thu Sep 06, 2007 6:01 am
newest violet can't merge igis, anymore - no idea, why ;) - an elder version was able to do that...
vux
Post by vux » Thu Sep 06, 2007 6:05 am
thanks i go to try old version
and experiments with simple images
ps - if this metod simple - why nobody using it;)?
Post by Kram1032 » Thu Sep 06, 2007 6:58 am
'cause most ppl prefer to render it correctly and with full quality, on the first shot :P
vux
Post by vux » Thu Sep 06, 2007 7:07 am
OK :) . And I want to hear Ono about that
vux
Post by vux » Thu Sep 06, 2007 7:12 am
I mean in interrior. Where after 1 day of rendering noise is similar like after few hours. It is posible to speedup render with this method? :wink:
vux
Post by vux » Thu Sep 06, 2007 8:04 am
sory for offtop
How to set Y-Up Axis in Blender?
Post by Kram1032 » Thu Sep 06, 2007 8:06 am
not at all :P
it's your thread, isn't it? xD
AND the title of it says, a noob wants to ask some question - which is exactly, what you do. So, it's perfectly on topic ;)
DaveC
Post by DaveC » Thu Sep 06, 2007 8:20 am
Unfortunately, Vux, I'm afraid you may have to reconfigure your mind-set instead of Blender and learn to see Z as up/down and Y as backward/forward. I don't believe it can be reconfigured within Blender.
vux
Post by vux » Thu Sep 06, 2007 8:38 am
stupid question :wink:
Why Viloet dont have 32-bit output (tif,exr)?
vux
Post by vux » Thu Sep 06, 2007 8:41 am
:shock: - its very interesting - in all other soft this future is required
