Indigo Dev Update Q4 2020
Re: Indigo Dev Update Q4 2020
Hi fused, that's great news for the future of Indigo, I wish Metal performs better that OpenCL in MacOS, especially with the newly released AMD rx 6000 series.
I would like to ask you also, if you have any other plans feature-wise to share with us. Projection lighting for example is a feature I would like to see in Indigo, or this is a matter of plugin development?
Hi mpro31,
the thing with all these different compute APIs is, that they will all roughly run at the same speed, internally they all use the same compiler, output the same bytecode which then runs on the same hardware. So don't expect Metal to run any faster than OpenCL.
What Metal allows us to do, though, is to tap in to hardware accelerated ray tracing. Which should result in increased performance on devices that support it.
I'd say that is a core feature of Indigo, and I'm wondering if it can't already be done with a texture in the emission channel and a fitting IES file. Maybe...
Although it would be nice if Indigo could do that without the need for an IES.
edit: I tried, that doesn't work
thanks for the reply fused,
the issue with lower opencl performance in macOS compared to Windows (-40% speed) isn't a matter of opencl drivers?
also glad to read about for the projection lighting feature note
I wasn't aware of this. In Indigo, compared to running on Windows through bootcamp?
My statement was more about the theoretical.
But I'm also seeing some difference in Cuda performance between Windows and Linux, so I shouldn't be too surprised.
Exactly, compared to your benchmark page, Windows/ bootcamp results are on track, while macOS is lower, but my system is old (nvida 980) and drivers may be the issue
ErichBoehm
I think this tech is very neat, but it would be very helpful to see some UI change, such as an "undo/redo" buttons and a "history" window like Photoshop. Hope everyone is staying safe.
Thx for the reply fused
Honestly, i think it would be a great move to be able to render using CPU+GPU, everything here is about speed (Indigo already has the quality
Most of the greatest rendering engines (except Maxwell Render) are using Hybrid rendering methods to improve rendering times...Vray does, Thea Render does, Why not indigo?
- schwungsau
did you ask vray and thea user if they actually using cpu or GPU ? adding CPU gives only 20% more speed with 10 core i9, in most scenes even less. unless you 64 core threadripper. using moth makes scene laggy too.
i prefer to 2:30 minutes for print rendering and have a "workable" computer then have the rendering done 15 minutes earlier.
Its start to be interesting for animations, since extra 20% of speed in a movie that would render for 2 weeks is saving 3days.schwungsau wrote: ↑Mon Nov 16, 2020 6:10 amdid you ask vray and thea user if they actually using cpu or GPU ? adding CPU gives only 20% more speed with 10 core i9, in most scenes even less. unless you 64 core threadripper. using moth makes scene laggy too.
And my Threadripper gets very competitive to the GPU if you start rendering foliage scenes where a very high raydepth is needed...
Proposal ,Add the function of automatically saving IGI.
This is available since Indigo v1.
What 3D app do you work in, maybe somebody can guide you to the right checkbox
fourzeronine
Any chance in looking at integrating USD Hydra Render Delegate? Would be nice way to have Maya and Houdini support.
Users browsing this forum: No registered users and 91 guests
