Dryad - Tree Generator
http://dryad.stanford.edu/
This is really handy for trees and its very very easy to use - you can generate a tree in a single click & drag and export to .obj in one click.
I found it really fussy with video cards but apart from that it works quite well.
- im1200182461.png (235.28 KiB) Viewed 11602 times
- im1200182029.png (221.88 KiB) Viewed 11602 times
- ViennaLinux
- joegiampaoli
@yttrium88
I had a similar problem, ... I thought it would hang when it was doing
the "Populating treespace ... ", but I just had to wait longer then I thought.
So just give it some time! I know the splashscreen can be annoying in
this case.
nb: When I say "wait longer" I mean a minute or two!
take care
psor
this case.
take care
psor
"The sleeper must awaken"
I was messing around with leaf materials and ended up sticking with a 50% blend of dark green phong + light green diffuse transmitter.
I also found the generated trunk mesh to be completely useless for texturing and closeups so it is probably more useful instead as a 'scaffold' to model a nicer trunk around. Also, the meshes are quite unwieldy with high face counts so the decimate modifier is really handy in these cases.
Material Link
PS. Dougal2 - Is this the correct way to link to materials ?
Material Link
- im1200516059.png (224.79 KiB) Viewed 11188 times
- im1200517931.png (181.09 KiB) Viewed 11188 times
