PoC - animation
PoC - animation
If Mohammed will not go to the mountain, the mountain must come to Mohammed
a simple program to generate multiple IGS file and a single IGQ file to animate camera based on a list of coordinates imported from a DXF file.
Re: PoC - animation
a question to developers...
this is skindigo generated file: this is edited by me with a program I have made: The two files have the same contents.
At first launch of the second file, indigo says error on:
I have edited it in this way:
the same thing happened also with other elements.
At the end of editing I have tried to launch the file but indigo scene window acts in a strange way
what's happened???
<camera_type>
thin-lens-perspective
</camera_type>Code: Select all
<camera_type>thin-lens-perspective</camera_type>At the end of editing I have tried to launch the file but indigo scene window acts in a strange way
what's happened???
Re: PoC - animation
Probably Indigo is not stripping text values, wich means it expects the second form.
In other words, is a wrong value. All speculative
Aaaaand, it's great to contribute like you do Snorky !
In other words,
" thin-lens-perspective"Aaaaand, it's great to contribute like you do Snorky !
Re: PoC - animation
I have tried to delete all text indentation and works a bit better but no correct...
maybe a carriage return?
edit:
yes... i try "cr" "crlf" and "lf" ....
only without works
edit:
only without works
