Blender 2.5 Alpha 0 -- Released--
Re: Blender 2.5 Alpha 0 -- Released--
Neo0, theres 3 little buttons at the bottom of the viewport that let you switch between face/edge/vertex selection. Alternatively ctrl+tab+2 will get you in to edge selection as well.
The existing Blendigo won't and never will work with 2.5 - you'll have to wait until we get some new code released.
don't panic, we're working on it
- Doug Armand
Thanks for the definitive answer - means I can stop wasting my time with it for the momentdougal2 wrote:The existing Blendigo won't and never will work with 2.5 - you'll have to wait until we get some new code released.
Doug
Doug Armand
Doug Armand
- zeitmeister
Oh dear...
baking in blender should and must really be multithreaded. I can't make any use of my eight cores... it's a real pity.
Does anyone know why the boys don't work on that?
- Borgleader
Oh yes I forgot to mention that earlier, the only reason the examples I linked to on the BA forums work is because theyve been built with the new python API, anything prior to 2.5 wont work.Doug Armand wrote:Thanks for the definitive answer - means I can stop wasting my time with it for the momentdougal2 wrote:The existing Blendigo won't and never will work with 2.5 - you'll have to wait until we get some new code released.
Oh there they are... I had to switch to edit mode.. Thanks!remus wrote:Neo0, theres 3 little buttons at the bottom of the viewport that let you switch between face/edge/vertex selection. Alternatively ctrl+tab+2 will get you in to edge selection as well.
- Borgleader
A lot of the buttons/menus are context sensitive now, which means they wont randomly still be there when they dont apply.neo0. wrote:Oh there they are... I had to switch to edit mode.. Thanks!remus wrote:Neo0, theres 3 little buttons at the bottom of the viewport that let you switch between face/edge/vertex selection. Alternatively ctrl+tab+2 will get you in to edge selection as well.
The best example of this is in 2.49 when you select a lamp object you still have the "Editing Tab" which normally contains mesh functions like subdivide, remove doubles, ... However on a lamp object this tab is empty yet still present and therefore useless. Notice how in 2.5 due to much more context sensitive-ness
Aw..
After a few computer troubles, I figured out I needed to install 2.5 (can't use any of the prior versions), and now I learn Indigo doesn't work with 2.5..
Don't mean to be impatient, but any estimates on when the 2.5-compatible script will be up and running?
I am curiousGodzilla wrote:dougal2 wrote:The existing Blendigo won't and never will work with 2.5 - you'll have to wait until we get some new code released.
Aw..![]()
After a few computer troubles, I figured out I needed to install 2.5 (can't use any of the prior versions), and now I learn Indigo doesn't work with 2.5..![]()
- pixie
You're young, you've got time!Godzilla wrote:After a few computer troubles, I figured out I needed to install 2.5 (can't use any of the prior versions), and now I learn Indigo doesn't work with 2.5..![]()
So I've never really used blender before and I was wondering about something.. A lot of the time, Im going for a messy look, with objects scattered around my scene, as if someone dumped them there. Can blender's physics tools be used to arrange objects as well?
- Borgleader
http://www.blendercookie.com/2009/12/12 ... ender-2-5/
Holiday themed tutorial in blender 2.5 alpha0
Will 1.1.18 users have to stick with 2.49, or is a rewrite intended for that as well?
I doubt it.dmn wrote:Will 1.1.18 users have to stick with 2.49, or is a rewrite intended for that as well?
thx for it, realy interestingBorgleader wrote:http://www.blendercookie.com/2009/12/12 ... ender-2-5/
Users browsing this forum: Google [Bot] and 28 guests
