READ THIS POST! CALLING ONE AND ALL! HELP IF YOU CAN!
yes that means its not done but I think that you dont really have to support the other one its just that thats a way to submit your work without having to have a third party intervene. Like passing notes back and forth The sign up is so easy you dont even have to confirm it one your email. If you havent please read the updates i made to the post. Dont forget to look up the poke pictures and dont worry about submitting previous work. Just showing the progress of your project on here will work.
Ok I'm taking it easy, I'll post progress here. I guess you guys have timecooldude wrote:yes that means its not done but I think that you dont really have to support the other one its just that thats a way to submit your work without having to have a third party intervene. Like passing notes back and forth The sign up is so easy you dont even have to confirm it one your email. If you havent please read the updates i made to the post. Dont forget to look up the poke pictures and dont worry about submitting previous work. Just showing the progress of your project on here will work.
Started one already, stopped in the middle. Modeling can be fun, but gathering all informations to be productive and usefull to your project is too demanding of an involvement, sorry.
You'd better submit one or three pokees that have chances to be involved in a defined project, then challenge ppl on these few imho.
Re: READ THIS POST! CALLING ONE AND ALL! HELP IF YOU CAN!
HEY, I'M Just trying to bring this back to life before the project dies. We need your help. I think I'm even on the verge of begging
Please...we've worked to hard and we can't let this happen afters years of working. We need your help. Please...
What will be the license of your project ? Public domain, free, commercial ? Can I post the file in the forum ?
- 1482 tris, can be reduced. color + bump textures.
- ctzn_remoraid.jpg (17.75 KiB) Viewed 3571 times
hey a cute nice model
Wow that is wonderful please do post it. Thats an amazing model
I'm glad it can stay in the public domain, as much as it's allowed to be...
CTZn_remoraid.zip
The zip file includes the psd file with paths used for creation, and 2 textures directly issued. And the obj file !
I added extra polys for the fins, you will certainly want to merge some details together. I think polycount can easily be reduced also by painting these details into the bump texture.
hardware render
The pupill can be animated by moving the eye's UVs.
edit: I tweaked vertices around the body's central line at the last moment, UVs sould be projected again (planar projection).
CTZn_remoraid.zip
hardware render
Can you post an obj file with the remoraid already textured?
Huh... no.
Obj files are not dx files, but they do have a material definition file wich I deleted because it's of no use for me. Following is the content of the mtl file that should be attached with remoraid:
but I doubt that's what you want... can you tell more on your pipeline cooldude ?
newmtl blinn1SG
illum 4
Kd 0.00 0.00 0.00
Ka 0.00 0.00 0.00
Tf 1.00 1.00 1.00
bump Remoraid_BUMP.png -bm 0.0416
Ni 1.00
Ks 0.50 0.50 0.50
