Request: Process Priority
8 posts • Page 1 of 1
Post by Zom-B » Thu Jul 20, 2006 5:58 am
Hey Ono-Sendai...
Now after adding multithreading to Indigo your Renderer runs like hell :lol:
But by using both of my Cores the System just respons slower,
because Indigo uses all my CPU Power,
so I always have to reduce Process Priority to a lower Level by hand...
Is it posible to add Process Priority definition to the inifile.txt,
so I (and everybody else :roll:) don't always have to change it by hand,
if I want to keep working on my PC?
I think this is a loooooow Level Request, kind of luxus, but still handy :wink:
bye, and thanx for your great Render!!!
ryjo
Re: Request: Process Priority
Post by ryjo » Thu Jul 20, 2006 7:57 am
Zom-B wrote:Hey Ono-Sendai...
Hello :),
psExec (sysinternals.org) can launch a process with a given priority (haven't tried it though)
Post by Zom-B » Fri Jul 21, 2006 7:53 am
radiance wrote:i would'nt integrate this into the indigo core as it's not a good idea to let processes govern they're own priorities.
it's also not very portable from a coding point of view...
Hmm... isn't a good Idea you say... may I ask why???
By portable you mean, you can use the same exe on linux/unix
that I use on my Win PC???
Post by Zom-B » Fri Jul 21, 2006 3:03 pm
Thank you for clearing this up for me radiance :)
Post by OnoSendai » Sat Jul 22, 2006 3:07 am
I'll test out the priority stuff sometime and see if it helps.
Using all cores / virtual cores at once does totally own a computer eh :)
Post by Zom-B » Sat Jul 22, 2006 3:15 am
Ono-Sendai wrote:I'll test out the priority stuff sometime and see if it helps.
Yes it does :twisted:
The luxus of smoth multitasking on dual Core is gone, fells like my old 1 Core PC ^^
Using 3 threads more than using just using 2, but I stilll got other Stuff running...
mzungu
Post by mzungu » Fri Jul 28, 2006 9:00 am
Has anyone run some testing on 0.6 to see if multiple threads is faster than multiple clients (networked)? Just thinking, if you're needing to "break in" to the rendering process periodically to gain access to some CPU time for other stuff, then the client system is great for this. Just kill one of the clients when you need the power and fire it back up when you're ready to crunch in Indigo. But, if threads are faster, then... priorities can be changed on the fly in the TM.
Alternately, and I know this has been requested before, but if a render could be completely stopped, then resumed at a later time... that'd be cool! A big use of this might be for animations. You have a set number of frame files, say 300, and you render thru all @ 20 min each. Then you can cycle thru them again, refining them for another 20 - and soforth until you get to acceptable quality levels. Combining this with anti-noise filters might make animation possible! :)
-mzungu
"The fear of the Lord is the beginning of wisdom" - Solomon
Post by Zom-B » Mon Oct 09, 2006 2:22 pm
Hey Guys...
I just dicovered that for us C4D Users, Indigo takes the Prozess Priorety of Cinema, when started from this App!
So reducing C4D to lower Prozess Priorety will start alle Indigo Renderings with this lower Prozess Priorety too.... nice! :D
