by suvakas » Sat Jul 05, 2008 5:26 am
Are you sure?
Works fine here.
Grimm
by Grimm » Sun Jul 06, 2008 12:38 pm
I just ran into the same problem on my cluster. I'm using V1.0.9 on linux and I set the haltspp to 200 and it's still going strong at over 300. Indigo did see the command when it started:
Starting server on port 7777...
Setting halt samples per pixel to 200.00000 samples per pixel
Using base Indigo directory path '.'.
And here is a current snapshot of the process:
Display took 20.05922 s
Time elapsed: 13 m, 9 s
Done 321920000.00000 samples (349.30556 samples per pixel)
407841.56385 samples / second (2.45193 micro-seconds / sample)
Receiving frame from 10.0.0.2:
num_samples: 10350000.000000
width: 2564
height: 1444
Frame received. (lock wait time: 0.00 s, transfer time: 0.81 s)
Applying diffraction filter...
Done.
Very strange.
Grimm
Grimm
by Grimm » Sun Jul 06, 2008 12:53 pm
Interesting, I just re-ran it but instead of using the command line parameter, I set the haltspp in Blendigo and it worked.
Something must be broken with the command line parameter.
Grimm
by suvakas » Sun Jul 06, 2008 10:49 pm
I use it from command line
Grimm
by Grimm » Mon Jul 07, 2008 8:19 am
Well something must be different, either it's the linux version or I didn't put the parameter in the correct spot, or ... ?!?
Either way I have found a way that works.
Grimm
mrmoose
by mrmoose » Tue Jul 08, 2008 2:07 am
I retry with indigo GUI and command-line and the render doesn't stop.
I use XP sp3... when i had sp2 -haltspp parameter worked...
Thanks for your replay
