kikeonline
by kikeonline » Thu Jun 05, 2008 9:34 am
Is it possible for Indigo to have a Pause & Resume option in the future???
Sometimes with big resolution renders I wish I can pause it and continue later on.
kikeonline
by kikeonline » Thu Jun 05, 2008 11:35 am
the firts one does not run in wine and the second one has a space problem in the directory path under wine
by CTZn » Thu Jun 05, 2008 12:37 pm
Hi
there are plenty of utilities for linux wich allow to freeze applications/threads, that will allow you to refresh the cpu while keeping Indigo alive (no calculations will occur but the app isn't killed).
Now by saving to igi you can kill Indigo and restart it later, using the -r option; it takes two parameters, the igi and the scene files.
Something like
indigo.exe -r [path/to.igi] [path/to.igs]
Resuming was a long-time request wich was fullfilled.
daniel_nieto
by daniel_nieto » Thu Jun 05, 2008 5:01 pm
jejeje simon, mi resumer esta diseñado para correr en güindos jejeje... la neta no sé como diseñarlo para que tenga compatibilidad con el wine para linux.
From México, Daniel Nieto .·.
by pixie » Thu Jun 05, 2008 10:19 pm
your resumer is quite nice daniel, but...
there's no buts! it's simply awesome!
It's simple and do what it stands for and more (it even allows one to run indigo on network). As for the problems in wine, I assume that installing the .net framework might solve the issue.
