[Bug] Strange "Light Mask"!? - **EDIT** solved in
5 posts • Page 1 of 1
Post by Zom-B » Sun Aug 27, 2006 12:12 pm
Hi everybody...
I created a Lamp Scene to test some Light Parameters, and get a very strange visual Bug on my MeshLights
(I used Peak here, but tested with BlackBody with same result!:
This strange "Mask effect" could be reproduced by moving the Camera:
HERE you can get XML + 3DS Files & C4D Source... any ideas?
** EDIT **
solved in 0.62!
Behrendt
Post by Behrendt » Sun Aug 27, 2006 7:11 pm
They seem to get transparent. Try to create a mesh ,without meshlight tag, which is a little little little bit smaller than the meshlight.
psor
Post by psor » Mon Aug 28, 2006 6:59 pm
Hello Zom-B!
I had a quick look over your scene ... and *ding* *ding* *ding* ...
the bidirectional support is borked right now, so you have to
disable it until it's fixed by Nick, then your scene will render fine. ;o))
So again to anyone ... DO NOT enable bidirectional support right now! :P :D ;)
take care
psor
Post by Zom-B » Tue Aug 29, 2006 2:13 am
psor wrote:So again to anyone ... DO NOT enable bidirectional support right now! :P :D ;)
Ok thank you for the Info! I thought "BiDi" just did some Problems with using Bump Maps... It seems there is broken more.
So therefor Nic is working on new Code for this :D
Post by OnoSendai » Tue Aug 29, 2006 2:45 am
Yeah there are issues with meshlights and bidir :)
