DoF and Instancing
6 posts • Page 1 of 1
Bandar
DoF and Instancing
Post by Bandar » Tue Jan 23, 2007 12:45 am
It seems, that when using multiple instances there is no DoF. First I thought it is due to the <autofocus/> but when i removed it and tried even an aperture_radius of 0.5 nothing happened.
domparis
Post by domparis » Tue Jan 23, 2007 1:55 am
No prob with instancing and dof here, perhaps a scale problem, be sure to work with real value as possible, it help of anticipation of what dof will look, remember that indigo working unit is meter.
Dom
P.S.: Be sure to correct the focus distance correctly, don't know what exporter u used
P.S.2: Sorry for my english :oops:
zsouthboy
Post by zsouthboy » Tue Jan 23, 2007 6:38 am
DoF isn't something that can "break" in Indigo, just because of the way it works :)
More than likely your scale is too small.
manitwo
Post by manitwo » Tue Jan 23, 2007 9:23 am
zsouthboy wrote:More than likely your scale is too small.
i think you meant too big 8)
zsouthboy
Post by zsouthboy » Tue Jan 23, 2007 10:12 am
No, smaller.
If his scale was for example 1 cm per unit, DoF (technically, less depth of field) would appear to be very wide, even at large apertures.
Increasing his scene by 100x would make the DoF appear correctly, in relation to "sensor", lens length, and aperture (as circle of confusion is dependent on these factors).
Bandar
Post by Bandar » Tue Jan 23, 2007 10:28 am
how can i scale a whole scene?
Users browsing this forum: No registered users and 110 guests
