IndigoDriverExcep
IndigoDriverExcep
I am loading a salon9.igs file in indigo. It works well in graphical and console mode.
I want to do networking. I put the folder "escena" with the igs and textures "shared".
I write C:\indigo_v1.0.9_3>indigo.(exe o _console.exe) \\192.168.0.128\escena\salon9.igs" -n wm -t 2
and I get the following error:
IndigoDriverExcep:SceneLoaderExcep: failed to open XML doc from path
'\\192.168.0.128\escena\salon9.igs':Failed to open file.
and in the log:
SSE present.
SSE2 present.
SSE3 present.
Using base Indigo directory path ''.
Scene file path: '\\192.168.0.128\escena\salon9.igs'
Using working directory path '\\192.168.0.128\escena'.
Loading Scene '\\192.168.0.128\escena\salon9.igs'...
What might be the problem?
Greetings
and in the log:
SSE present.
SSE2 present.
SSE3 present.
Greetings
- PureSpider
This rendering is done with two computers, master (also working) and slave:
master = \\ip_master\scene\test.igs -n wm -t 2
slave = -s n \\ip_master -t 2
through a router
but the file salon9.igs continues to give me the same mistake that opened the post.
render time: 20 m.
through a router
render time: 20 m.
- im1212762928.png (829.76 KiB) Viewed 2677 times
- PureSpider
cpfresh:
Yes is the same version on two machines.
The problem is to upload the file on the master. This file load perfectly normal mode (not networked).
Let me give objects in different layers and make incremental exports to see where the fault may be:
-- Whether en path from textures
-- Huge file,
-- Etc. .....
Greetings.
-- Huge file,
-- Etc. .....
Greetings.
I have already managed to load my scene complete salon.igs network.
I changed the names of folders textures to other shorter, it seems that the network has trouble with long names, I reviewed the route of textures and optimize the vertices of the mesh.
The commands were:
master: indigo_console.exe \\192.168.0.128\salon\salon.igs -n wm
slave: indigo_console.exe salon.igs -n s -h 192.168.0.128
Thank you all.
The commands were:
Thank you all.
