Blender light exporting problem!!!
5 posts • Page 1 of 1
Modude
Post by Modude » Sat Feb 02, 2008 8:47 pm
Whenever I hit Blendigo to export under file>export>Blendigo, and then the scripts page comes up, then I hit export scene, and this window comes up, and says "scene must contain at least one light." I tried all I could, I got all I need to use Indigo, the scripts and everything, and installed everything, but I cant export anything! Help! in the file attachment there is a screenshot of what comes up when i hit "export scene."
heres what comes up.
Indigo problem.JPG (74.03 KiB) Viewed 4437 times
Big Fan
Post by Big Fan » Sat Feb 02, 2008 9:00 pm
well do you have a light in there? :D
you either need a sun 8) or a mesh that glows... :idea:
joegiampaoli
Post by joegiampaoli » Sat Feb 02, 2008 9:18 pm
:idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea:
Joe Giampaoli
My Indigo Gallery
Post by Kram1032 » Sat Feb 02, 2008 10:04 pm
The only lamp that directly works, is a sun. To activate it, you need to go to the environment tab and select "Sun and Sky" in the drop down menu.
If you don't want to use a sun to enlighten your scene, you need to build a mesh and give it an "emitter" material in blendigo.
The light will only flow in the directions of your normals. It wont glow in the other direction.
Modude
Post by Modude » Sun Feb 03, 2008 9:46 am
Thank you! I never realized I needed a sun. :oops: :D
Users browsing this forum: No registered users and 66 guests
