Is there any subdiv on you water at all (that needs to be a volume btw, see tutorial!)?
Is the material UV mapped?
Seems both questions can be answered with a no...
water is not rendering in my laptop
Re: water is not rendering in my laptop
Yeah, I have to agree... looking at the image you posted it doesn't look like you followed the tutorial at all...
If you follow it properly you should get perfectly good water, I used the exact same process in the pool scene I just posted.
http://www.indigorenderer.com/forum/vie ... 1&start=45
it is crashing now while rendering this......
- skup_pool_tut_2.zip
- wats the problem...???
- (34.55 KiB) Downloaded 208 times
please uploade the PIGS (save as such from Indigo GUI before starting rendering), so non Sketchup users can check it out too
here it is...
- skup_pool_tu.pigs
- (16.18 KiB) Downloaded 195 times
what is the problem....???
No problem for me, renders flawless here. eats up only 330MB of RAM:
Maybe the 32bit build has some issues?!
First update to the latest Indigo build: Indigo 3.8.2
on a crash check the "view problem details" button on the bottom!
If a minidump is created for the crash, the zip it and send it to glare, so the can check it out...
