[REQ] Random Seed for Render-Q Files ** in 3.6.x **
Since I do quite some animations in Indigo I would be glad to see a option to have a new random seed for each file rendered by the Render-Q.
At the moment Indigo only does a random seed for each instance of Indigo started, and keeps if for all files opened and rendered in that.
The result is that noise stays quite static over the image for animations and is very ineffective to get rid of by temporal denoisers that check multiple frames and identify noise by rapid pixel changes from frame to frame...
So please create some IGS tag like <random seed>true</random_seed>
Re: [REQ] Random Seed for Render-Q Files
Hi Zom-B,Zom-B wrote:bump -.-
we did introduce a per item seed in 3.6.x.
It was either that or a global random seed option and we decided in favor of the per item seed.
Seems it simply wasn't mentioned in the Changelog, but after checking, I found a seed value in the Render Q settings of the GUI
Now only some Exporter support is needed for that feature
I am pretty sure you were given some version with some kind of support for itZom-B wrote:Seems it simply wasn't mentioned in the Changelog, but after checking, I found a seed value in the Render Q settings of the GUI
For everyone else, sorry to keep you waiting. Will be back to doing exporter work very soon
Nor elsewhere :/Zom-B wrote:Seems it simply wasn't mentioned in the Changelog
By the way did I make it up or were the *_spectrum tags rendered obsolete ? Got rid of'em.
Re: [REQ] Random Seed for Render-Q Files ** in 3.6.x **
Is there a similar seed tag for the render_settings ?
afaik its only been a command line attribute since day 1
best way is now to create a Q file for animations now, define seed there and load it in Indigo after export is done.
START /B /LOW indigo.exe -n wm -p 7100 -seed 1234polygonmanufaktur.de
The command line it will be then, thank you Arthur.
What's Indigo's default seed ? If i'm correct by default Indigo is using the same seed isn't it ? (I set it to 1337).
The exporter will be shooting by default a random seed in the range 0-10000 for each render, can this be improved somehow ? Is this even a good default behaviour ?
indigo default is 0, and each core gets a +1 seed, check the log after render started.
your range in random seeds seems enough... temporal denoiser usually don't take more then 5 frames into account for denoising, as long as these 5 frames in a row have not the same seed it will work nicely
thank you, much appreciated !
- pixie
Video or it didn't happen!Zom-B wrote:indigo default is 0, and each core gets a +1 seed, check the log after render started.
The chance to have at least two same seeds in a following row of 5 random picks out of 10000 should be quit easy to calculate, but my math skill is actually non existing -.-'pixie wrote:Video or it didn't happen!
Users browsing this forum: No registered users and 181 guests
