Googog Mogog
by Googog Mogog » Mon Nov 21, 2011 7:35 am
Hello guys!
When we gonna have GPU accelerated bi-directional Path tracing support in Indigo render.
Because up coming Lux Render version 0.9 has support for GPU accelerated Bi-directional path tracing.
by Zom-B » Mon Nov 21, 2011 9:04 am
Seems you mixed up here something, but I'm open for any proof: link?!
by CTZn » Mon Nov 21, 2011 11:34 am
There's nothing impossible, lycium stated that OnoSendai had it working on an early GPU implementation. For the least, as a proof of concept am I guessing.
Sorry, I'm too lazy to retrieve the link to that statement ;P
by Zom-B » Mon Nov 21, 2011 11:47 am
I know that it is possible, and also has been done (
link), but afaik it isn't build in in any
availible unbiased renderer atm.
I follow Lux development a little, and think I would stumbled on such a feature.
I didn't want to sound arrogant with my first commend, just interested
dougal2
by dougal2 » Mon Nov 21, 2011 11:22 pm
It's true, LuxRender does have the beginnings of a hybrid CPU+GPU bidir integrator, however although it seems to work, it isn't finished and there are some known problems with it still.
by Zom-B » Mon Nov 21, 2011 11:30 pm
Kudoz to the Lux team, missed that feature totally! thanks for the Info doug.
by lycium » Tue Nov 22, 2011 1:11 am
dougal2 wrote:It's true, LuxRender does have the beginnings of a hybrid CPU+GPU bidir integrator, however although it seems to work, it isn't finished and there are some known problems with it still.
Well, we definitely haven't forgotten about GPU bi-dir, but judging from that screenshot even our CPU single-dir has nothing to worry about
Googog Mogog
by Googog Mogog » Tue Nov 22, 2011 5:07 am
Also i want invisible Light emitters features in Indigo render just like maxwell render
Googog Mogog
by Googog Mogog » Tue Nov 22, 2011 5:40 am
Hey lycium nice discussion u have there.
But According to me no unbiased renderer is true light simulator. The real world light behaves very differently then any unbiased renderer. What happen in real world is that a light source emits light and when this light hits the surface of an object the surface which is visible to both direct and indirect light becomes light itself which means light reflect itself from the surface of an object which is based on the reflective properties of an object and light intensity which is coming from direct light source.
As an example take a torch and just for experiment go in dark room with some objects. Turn torch light direction to white diffuse wall of that room. When u do that u will see that light will reflect from wall which is of course indirect light and this indirect light cast nice shadows onto objects just like Light source.This is reflective light . And this is what real world do. Not to simulate any photons ,bounces what so ever in real world Light got no particles. In real world as light emits it will reflect same as its from the Direct light source but with different intensity and properties based on the surface of an object.
This is my observation.
by lycium » Tue Nov 22, 2011 5:50 am
Unbiased has a very specific technical definition, it's not a matter of opinion
It's about the correctness (on average) of a statistical estimator, which is what Monte Carlo renderers fundamentally create.
Please see:
http://www.cgafaq.info/wiki/Bias_in_rendering
As for "true light simulation", if we restrict ourselves to
Classical Geometric Optics (no quantum phenomena, no interference etc.), then Indigo is pretty much correct.
by Headroom » Tue Nov 22, 2011 12:34 pm
Googog,
With all due respect to your observations, please educate yourself before posting!
There are people that would somewhat disagree with what you observe as the real world behavior of light. Such are for example Richard Feynman who has received a nobel price for his work in the area of Quantum Electro Dynamics. You mentioned Maxwell earlier. Has it ever dawned on you why this software is called Maxwell or are you really not familiar with the work of James Clerk Maxwell ?
There are a good number of people that have worked for decades of their academic careers on lighting simulation algorithms an have compared these with real world measurements. Phong, Blinn, Ward .... sounds familiar ?
If you dive a little deeper into Indigo's abilities and read through the forums you will find that Inigo is indeed quite accurate in simulating the behavior of light.
ENSLAVER
by ENSLAVER » Tue Nov 22, 2011 1:28 pm
inb4 "it only exists when you observe it"
