How to use GPUs from command line render?
Come here for help & support.
5 posts • Page 1 of 1
cgbeige
Post by cgbeige » Sat May 21, 2016 9:20 am
I don't see any command line flags to use GPUs for render in the CL help
Re: How to use GPUs from command line render?
Post by Oscar J » Sat May 28, 2016 7:02 am
Do you mean activating GPU from scene files?
cgbeige
Post by cgbeige » Sat May 28, 2016 7:05 am
so if I set the scene to use GPUs in the file, it will use them automatically when command line rendering?
cgbeige
Post by cgbeige » Sat May 28, 2016 3:06 pm
actually, I just tried that and it doesn't stick. If you open the file again or try to command line render it after changing to OpenCL with GPU and saving, it will revert back to CPU rendering.
cgbeige
Post by cgbeige » Fri Jun 03, 2016 5:53 am
ok - got answer in email and verified this works. Use arg:
--settings "<gpu_path_tracing>true</gpu_path_tracing>"
