Autosave Image to Disk question
Come here for help & support.
tar_gniK
3D Software: 3ds Max
Post by tar_gniK » Sat Oct 27, 2012 3:41 am
Hello Glare team, I hope you can help me.
When I start a render, and I specify the camera/tonemap settings (for example Ektachrome 64TCD, D50 whitepoint, ev 3.0, ISO 75), those settings do not seem to carry over in the actual autosaved image.
At the very least, the camera settings and camera preset are saved, but the whitepoint is not. On other occasions, the defaults are saved. Is this intentional? I posted a question on this some time ago, but the problem (if it is one) remains.
Re: Autosave Image to Disk question
Post by Pibuz » Sat Oct 27, 2012 5:08 am
Following this thread.
I know some time ago I was answered that autosaving also the current layerblend state was memory consuming, but still I think that old feature should be re-introduced. It was very handy. 8)
tar_gniK
Post by tar_gniK » Sat Oct 27, 2012 8:02 pm
Still no official response? Seeing as I have paid for this software, I would have expected something at least in the way of acknowledgement of my query. Currently rendering a scene, and the problem is still there...
See screenshot below. Right is auto-saved image, which is clearly different to what I have specified. In most situations, this doesn't concern me, as I save from the GUI anyway.
On other occasions, where I have started a render, closed it (maybe if I am not happy with something), but then changed my mind, the auto-save is useful but I don't understand the point if the image generated is useless for my needs. This problem was not present in the 2.xx versions, AFAIK.
ENSLAVER
Post by ENSLAVER » Sat Oct 27, 2012 8:51 pm
It is the weekend =P
I am guessing they can probably just add a checkbox for this option.
Post by Pibuz » Sat Oct 27, 2012 9:40 pm
Post by fused » Sun Oct 28, 2012 1:09 am
Which version of Indigo are you using?
Post by Pibuz » Sun Oct 28, 2012 1:18 am
3.4.12 at the moment.
Are you saying that you re-arranged something in the latest? :D :D :D
tar_gniK
Post by tar_gniK » Sun Oct 28, 2012 1:31 am
Same as Pibuz, 3.4.12.
Post by fused » Mon Oct 29, 2012 11:31 pm
I had a look at it and auto image saving *seems* to work as intended. I tested light layers, whitepoint and tonemapping.
I think what you might be running into is that the image isn't saved imediately after changing any setting, but that it's saved in fixed intervals.
This is defined by the <image_save_period> setting in the Indigo scene file, or (most likely) "Image save period" in you exporter (if available). The default value is 60 seconds.
Cheers!
Post by fused » Mon Oct 29, 2012 11:34 pm
Pibuz wrote:3.4.12 at the moment.
I fixed the problem with layer settings being ignored in 3.4.7:
Indigo Renderer 3.4.7 changelog wrote: * Fixed some tonemapping changes not being applied for automatic image saving.
Post by Pibuz » Mon Oct 29, 2012 11:53 pm
Very cool.
Gonna test that. Thanks!
tar_gniK
Post by tar_gniK » Tue Oct 30, 2012 12:21 am
Thanks very much for the reply.
Just tested this further, and it seems that if you specify the camera settings within the exporter (in my case Maxigo 3.07) the auto-save is correct. However, if I change the whitepoint, the auto-save is not updated. Screenshot below: I specified Ektachrome 64TCD with E whitepoint from the exporter. I changed it within Indigo to D55, but the auto-save stays as the default. :?
Strangely enough, if you change the camera preset, the auto-save updates. The whitepoint does not.
I'm no expert on these things, but possibly a bug somewhere? I should add that this is irrespective of the image auto-save period.
Post by Pibuz » Tue Oct 30, 2012 1:16 am
..hmm: yes I can confirm the behaviour. The auto-save operation takes into account the settings of the export application. If I change something during the rendering, the current image state is not autosaved as I see it on the Indigo GUI.
Post by pixie » Tue Oct 30, 2012 1:23 am
Perhaps if you save the scene it helps?
tar_gniK
Post by tar_gniK » Tue Oct 30, 2012 1:25 am
Just installed 3.4.13 from .12 and autosave works correctly. :wink: Maybe I should have tried that first. :roll:
