Hallo, I have installed Indigo Render at first and licensed it. Then I install Skindigo in Skechtup. However when I render with Indigo, there is alway Trademark(watermark) on the image(but watermark option is closed, and it shows the license is verified). At the same time, in the extension management of SkechtUp, it shows that Shindig is without signature. I don’t know how to solve the problem, do you have some suggestion? Thanks a lot!
p.s.: I bought the student vision for indigo renderer 4
about Skindigo
Re: about Skindigo
it sounds like you activated your Indigo with a node license. The node license will show as valid but only work when using Indigo as a network slave (node). Please generate another license key for the standalone version of Indigo (the one that doesn't say "node").
I hope this helps.
Best,
Yves
I hope this helps.
Best,
Yves
