Setting unique save interval and file name (timelapse)
Come here for help & support.
4 posts • Page 1 of 1
kklors
Post by kklors » Tue Feb 19, 2013 11:17 pm
Wondered if it's possible for quite a while already.
Would it be possible to set a save/update interval of let's say 5 seconds without Indigo overwriting the previous update but create a new image for each save of the same scene?
Obviously this would serve only an educational and fun purpose of recording a timelapse to see how problematic areas like transparencies or shadows develop over time and how many samples are needed.
I understand that this would not work as benchmark.
Alternatively a force update in the render viewer would work as well so one could simply screen grab the whole process, although it would only allow renders in screen resolution.
Re: Setting unique save interval and file name (timelapse)
Post by Zom-B » Tue Feb 19, 2013 11:24 pm
Afaik it isn't possible to do so directly in Indigo.
But I would suggest it would work with something like a "backup software/tool"
that backups data in a certain time interval, or directly after file creation.
Using such a software, you simply set your Indigo save interval to lets say 2 minutes, and tell that tool to create a new backup of the file/folder each 2 minutes.
You can find a bazillion off small tools and free software over at http://www.softpedia.com/
Maybe you get lucky :)
kklors
Post by kklors » Tue Feb 19, 2013 11:33 pm
Nice workaround! Haven't thought of that : P
Will give it a try later this evening or tomorrow.
Post by CTZn » Wed Feb 20, 2013 12:54 am
There has been a similar request yeeaaars ago, I think it was me fascinated by the MLT process :D
Also, you can force Indigo to cease rendering after a given sample per pixel count, as a float (ie: it can be below 1.0) and go on with resuming. It's rather tedious though but this could be batched I assume.
