Wood Floor gives the following error:
Error: SceneLoaderExcep: ObjectExcep: No such uv set 'default' (In element 'model', around line 55918, column 5)
This is with a UV set called default in place on the model. Using Blendigo 2.0.6.1/ Indigo 2.0.8
Borgleader's Material Emporium
- Doug Armand
Re: Borgleader's Material Emporium
Doug
Doug Armand
Doug Armand
- Borgleader
I'm able to render them because I made them but if you use them externally you cant, so you're gonna have to look at the preview in the database, or open the file in a text editor and shove the settings in, or...bug Smartden to somehow have an "import settings" function.Doug Armand wrote:Wood Material has the UV Set to 'default' which is not consistent with the rest though easy to fix.![]()
BTW how does one render these using the preview? when I try in Blendigo it says can't preview external material so I have to render the scene instead.
EDIT: Baby blue & green plastics should be fixed now.
those wood floors look great!
kind of off topic:
is anyone able to fix the UVs on the base of the preview model, you can see the lines in the wood planks going all wavy and skewed.
kind of off topic:
Users browsing this forum: No registered users and 46 guests
