The emitting mesh is quite low poly and it's black diffuse ... so the problem is not there...Zom-B wrote:Any info about your system could help hereJotaSolano wrote:Any advice on the other thing, (rendering time)... before you said that sometimes when you don't use emitters properly, it can get pretty slow... (i know photon rendering is slower than the other kind... like blender internal...) but still... 30 min should be enough for this simple scene... or not?
A advice would be to keep emitting meshes "low Poly" if possible... also use a pure black diffuse with emission for this!
I'm suspecting my pc is not the fastest one around lol... the thing is that when i bought it it wasn't intended for 3d rendering... just simple graphic design... that was about a year ago... then I discovered Blender and it all changed...
It's a Intel Core 2 Duo T6400 2.0GHz, 800Mhz, 2M L2 Cache an 3GB RAM
The video card is a 512MB ATI Mobility Radeon HD 4570
Running Vista 32 bit
For the record it DOES render fast using vray for rhino and blender internal... quite fast... even with high quantity of transparencies and reflections, HDRs, etc... (so that's why im asking lol)
