Specularity/Hardness reference for Blender
14 posts • Page 1 of 1
kououken
Post by kououken » Mon Nov 06, 2006 10:38 pm
I made this test image to get a feel for the range of specularity and hardness selectable from blender. Makes it easier to pick settings for say, dry silk, or slimy frogskin, etc. You can also see how specularity settings above 1.0 don't make the reflection any sharper, but the consecutive reflections get out of control quickly.
Hope this helps someone. I'm just not patient enough to do the materials in the xml by hand! :shock: Are there any other renders to reference? Like changing IOR, or transparency for example?
-KouOuKen
tungee
Post by tungee » Mon Nov 06, 2006 10:39 pm
tampopo , hanna bi ,ran ...
that looks great, but what means hardness? what parameter is meant?
lego
Post by lego » Mon Nov 06, 2006 10:55 pm
hardness = exponent
skypa
Post by skypa » Mon Nov 06, 2006 10:58 pm
Great reference, thank you for that. Getting the spec and hardness right has always been a little try&error-ish. :)
Post by OnoSendai » Mon Nov 06, 2006 11:17 pm
And what is specularity in the blender exporter?
I have a funny feeling it's fresnel_fraction, in which case, it shouldn't go above 1 :)
lego
Post by lego » Mon Nov 06, 2006 11:46 pm
OnoSendai wrote:And what is specularity in the blender exporter?
mmm that's strange!
I always thought that indigo specularity was taken from blender specular color!
but I did a test and I saw that it takes in consideration the specularity slider too...
so if I set spec color to 0.8 0.8 0.8 and specularity to 0.5, I get an indigo specularity of 0.203 0.203 0.203.
If I set spec color 0.8 0.8 0.8 and specularity to 2, I get an indigo specularity of 4.x 4.x 4.x :shock:
maybe an exporter bug? I'm using the last version
kououken
Post by kououken » Tue Nov 07, 2006 12:51 am
Well shoot.. here I thought I had finally figured out how things worked.
What would the settings in blender be, for example, for a perfect mirror? :(
-KouOuKen
Post by OnoSendai » Tue Nov 07, 2006 12:55 am
kououken wrote:Well shoot.. here I thought I had finally figured out how things worked.
<specular>1 1 1</specular>
<diffuse>0 0 0</diffuse>
lego
Post by lego » Tue Nov 07, 2006 1:01 am
in the exporter the specularity is set as this
colGamma(mat.specB*specfac)*SpecularGain.val
for each color
I think specfac is the specular slider
I don't know what speculargain.val is...
I'll try to use just
colGamma(mat.specB)
zuegs
Post by zuegs » Tue Nov 07, 2006 1:26 am
SpecularGain.val is not used currently and is constantly set to 1.0
so specularity is defined as following:
Red = colGamma(mat.specR*specfac)
Green = colGamma(mat.specG*specfac)
Blue = colGamma(mat.specB*specfac)
:wink:
Post by OnoSendai » Tue Nov 07, 2006 1:30 am
Well... whoevers on blender duty.. they need to clamp each component of the specular colour to the range [0, 1]. :)
lego
Post by lego » Tue Nov 07, 2006 1:41 am
zuegs wrote:SpecularGain.val is not used currently and is constantly set to 1.0
:wink:
Are you sure?
I modified the script leaving
colGamma(mat.specR)*SpecularGain.val
I set a spec color of 0.4xx and hit export
in the xml I had a specularity that was roughly 0.25 times the one set in blender!
And I don't get the need to use the specfac value in that expression! it would be much more intuitive to have spec col slider --> indigo specularity
DaveC
Post by DaveC » Tue Nov 07, 2006 2:49 am
How very odd!! Last night I posted a final render inspired by exactly the same idea as this image. You can see it at this link: http://www.indigorenderer.com/joomla/in ... temId=3406
I would have done one the same as this one, but I didn't have the patience! lol
zuegs
Post by zuegs » Tue Nov 07, 2006 2:56 am
@lego:
as long you have the "colGamma()" function in the formula you do a inverse gamma correction dependent of the col-exp slider in the exporter... you can set col-exp slider to 1.0 or remove "colGamma()" to match values between Blender and Indigo.
@OnoSendai:
you are right, will try to remember this for next release :oops: exporter is still very experimental :wink:
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot] and 90 guests
