So my question: Is there someone capable of creating velvet shader. Even better would be if some genius could create fur shader
Velvet shader
- Reinuvader
Velvet shader
Have anybody done velvet shader. As I understand it is possible with shaders, but I don't speak any code. I tried metal material with exponent 10 but then it looks like silk/satin.
, but of course this would be overkill for velvet-like surface.
Re: Velvet shader
Real velvet shader is not currently possible (it requires some advanced BRDF models featuring some effects such as retroreflection)
I would be very happy to tweak it if it was possible!
Etienne
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
- Reinuvader
Re: Velvet shader
OK, but then, have someone successfully faked velvet in decent manner with indigo? Any ideas and tricks would be appreciated.
- Reinuvader
Re: Velvet shader
I'm thinking if there is possible to use fresnel effect to boost color/light where surface is turned away and lower the surface reflection on areas where normals are directed toward us?
- zeitmeister
Re: Velvet shader
I think that fresnel has been (planned to be?) integrated ...
My last information is that you can't access normal direction information fron ISL yet.
- Reinuvader
Re: Velvet shader
I found something interesting from older topics:http://www.indigorenderer.com/forum/vie ... f=7&t=7505
Second picture is close to what I am willing to do. So how can I use this code. I tried it, but it doesn't work. What to do to get similar result?
Re: Velvet shader
I'm trying a different approach. Though it relies on bump mapping only it should be more accurate (I think). Bump code:
Just playing with numbers, there's nothing scientific here
def eval() real :
(sin(texi() * 314159.27) * sin(texj() * 314159.27))
/ (31415.927 * 2.0)obsolete asset
Re: Velvet shader
That looks pretty cool CTZn.
Upload to MatDB?
Upload to MatDB?
Re: Velvet shader
I'm glad you like it, Nick. I'd like to experiment more before I matdb one
but I saved an igm, let's see...
What's really exciting is that one can have as many responses to lights direction as he can code micro-patterns. Makes a lot of variations for a rather simple material. Will illustrate this.
That current pattern is about the most generic one.
PS: the shader is UV dependent, normally it should be tweaked for the scene for best results (density/length).
- velvet.igm
- (751 Bytes) Downloaded 400 times
Re: Velvet shader
I already tested several micro pattern shaders once, but I was limited by the non-zero derivation length of Indigo for bump shaders, thus it was impossible to make the patterns small enough for not being visible (or artifacting).
Did you use a shader or an image? Ono, was there any change of the way indigo derivates bump shaders recently?
Etienne
Etienne
Re: Velvet shader
The bump shader I used is above the render (and the igm below ;P).
I didn't notice that... ehr, derivation. I've got anisotropic effects without noticing the pattern, though I took care not to scale the pattern down too much (proceeding by order of magnitudes, 10x larger and it should be noticeable).
Thing is, you need an hires mesh coz it's agressive to shading normals.
Re: Velvet shader
Possibly a bit too close to cell-shading, but cool stuff !
Re: Velvet shader
Yep Lemo, the combination of U and V threads renders duller than U or V alone wich have a more pronounced anisotropy, by definition. It's also one setting among one zillion
You guys want the one ready to go material, ok
I think from now on I will release micro-patterns as one tile and it will be up to the user to take care of the UV placement, how does this sound ? Adresses my concerns with scaling, but you'll still have to learn to set bump value right...
Anyways, has someone tested that velvet igm already ? What gives, what wants ?
Re: Velvet shader
Etienne, I assume that bump has changed since you tried. Please don't take ombrage and enter the game !
Re: Velvet shader
I thought about it, and most probably that's because the "hairs" length is constant. I'll check this out in a moment.Lemo wrote:Possibly a bit too close to cell-shading, but cool stuff !
